# Execute SWML
> Call Flow Builder node to execute a remote SWML document and return to the current document.
Execute a remote [SWML](/docs/swml) document and return to the current document.
Use `%{return_value.['object_field']}` to reference the return values from the external SWML.
## **Output Node Connectors**
**`Condition`** `string`
The condition that is evaluated to determine which path to take. Additional conditions can be added by clicking the `Add condition` button. Additional conditions will act as JavaScript `else-if` statements.
**`Else`** `string`
The path to take if none of the conditions are met.
## **Node Settings**
**`URL`** `string`
The URL of the SWML document to execute. The URL **must** return swml in valid `JSON` or `YAML` format.
**`Params`** `object`
The parameters to pass to the SWML document.
**`Meta`** `object`
The metadata to pass to the SWML document. A JSON object to serialize.
**`Conditions`** `string`
The conditions that are evaluated to determine which path to take. Additional conditions can be added by clicking the `Add condition` button. Additional conditions will act as JavaScript `else-if` statements.
## **Example**
In this example, we will execute a SWML script that is hosted on a remote server.
When making a request to the server, we will pass the `User` and `Token` parameters.
The SWML document will return a JSON object with a [play](/docs/swml/reference/play) method field.
This play field will be used for TTS (Text-to-Speech) in the current document
and will welcome the user with the `User` parameter and say the `Token` parameter.
![Execute SWML node example that executes a remote SWML document.](https://fdr-prod-docs-files-public.s3.us-east-1.amazonaws.com/signalwire.docs.buildwithfern.com/a9a8a7ceba0c91f1dd204c421d59c6c1e6fb603697694b704b6dd28dda61daa4/assets/images/call-flow/nodes/swml_node.webp?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Content-Sha256=UNSIGNED-PAYLOAD&X-Amz-Credential=AKIA6KXJSKKNFOCF7G4B%2F20260817%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20260817T013048Z&X-Amz-Expires=604800&X-Amz-Signature=e9cabec0ccc464b5c1965710b5a24792ecdb954d600a9f464d538aaae0e8e028&X-Amz-SignedHeaders=host&x-amz-checksum-mode=ENABLED&x-id=GetObject)
### Execute SWML Node Settings
* **URL**: Self-hosted [ngrok](https://ngrok.com/) URL.
* **Params**: `{ "Content-Type": "application/json", "User": "user_1", "Token": "123" }`
* **Meta**: None
* **Condition**: `%{return_value.return_value} === 1`
### SWML Document
Below is the SWML document that will be executed.
```yaml andJSON
sections:
  main:
    - play: 'say: Hello <USER_NAME>, welcome to the SWML demo! Your token is <TOKEN>!'
### Server Code
Below is the server code that will return the SWML document.
#### Node.js
#### Pre-requisites
* [ExpressJs](https://expressjs.com/) installed in your environment.
* [ngrok](https://www.npmjs.com/package/ngrok) installed in your environment.
```js
const express = require('express');
const ngrok = require('ngrok');
const app = express();
// Body parser middleware to handle JSON payloads
app.use(express.json());
// Define the route
app.post('/swml', (req, res) => {
    let reqBody = req.body;
    console.log(reqBody);
    let user = reqBody.params.User;
    let token = reqBody.params.Token;
    const swml = {
        "sections": {
            "main": [
                    "play": `say: Hello ${user}, welcome to the SWML demo! Your token is ${token}!`
    res.json(swml);
// Start the server and use ngrok to expose it
const port = 5000;
app.listen(port, async () => {
    const url = await ngrok.connect(port);
    console.log(`Server running on ${url}`);
#### Python
#### Pre-requisites
* [Flask](https://flask.palletsprojects.com/en/3.0.x/installation/#install-flask) installed in your environment.
* [Pyngrok](https://pypi.org/project/pyngrok/) installed in your environment.
from pyngrok import ngrok
app = Flask(__name__)
@app.route('/swml', methods=['POST'])
def swml_route():
    # Extracting data from request JSON
    req_data = request.json
    print(req_data)
    user = req_data['params']['User']
    token = req_data['params']['Token']
    swml = {
        "sections": {
            "main": [
                    "play": f"say: Hello {user}, welcome to the SWML demo! Your token is {token}!"
    return swml
    port = 5000
    public_url = ngrok.connect(port).public_url
    print(f" * Running on {public_url}")
    app.run(port=port)
