*** id: 561a16a7-57d8-45c1-bf26-8464d9e30ec2 title: Switch devices during calls slug: /js/guides/switch-devices x-custom: ported\_from\_readme: true tags: * 'product:video' * 'language:javascript' * 'sdk:relaybrowser' sidebar\_custom\_props: platform: javascript max-toc-depth: 3 *** SignalWire Video API allows you to host real-time video calls and conferences on your website. In this guide, we'll learn to allow users to change the camera and microphone that's being used in the call. ## Getting Started If you haven't yet set up a video conference project using the Video SDK, you can check out the [build a video application](/docs/browser-sdk/v3/js/guides/build-a-video-app) guide first. After you have a video application set up, you can continue with this guide. ## Getting a list of supported input devices First, we want to find out what devices are available as input. Getting the list of media devices is handled by the `WebRTC` object available via `SignalWire.WebRTC` from the SDK. The methods in the `WebRTC` allow you to get the list of microphones, cameras, and speakers. ### Listing webcams To get the list of connected devices that can be used via the browser, we use the `getCameraDevicesWithPermissions()` method in `WebRTC`. The method returns an array of [InputDeviceInfo](https://developer.mozilla.org/en-US/docs/Web/API/InputDeviceInfo) object, each of which have two attributes of interest to us here: `InputDeviceInfo.deviceId` and `InputDeviceInfo.label`. The `label` will be used to refer to the webcam via the UI, and looks like 'Facetime HD Camera' or 'USB camera'. The `deviceId` is used in your code to address a particular device. ```javascript const cams = await SignalWire.WebRTC.getCameraDevicesWithPermissions(); cams.forEach((cam) => { console.log(cam.label, cam.deviceId); }); ``` ### Listing microphones Exactly as with `getCameraDevicesWithPermissions()`, we can use the `getMicrophoneDevicesWithPermissions()` to get a list of allowed microphones. ```javascript const mics = await SignalWire.WebRTC.getMicrophoneDevicesWithPermissions(); mics.forEach((mic) => { console.log(mic.label, mic.deviceId); }); ``` ## Changing webcams and microphones Once you have set up the video call with `SignalWire.Video.joinRoom()` or equivalent methods, we can use `Room.updateCamera()` and `Room.updateMicrophone()` to change devices. As a simplified example: ```javascript const roomSession = new SignalWire.Video.RoomSession({ token, rootElement: document.getElementById("root"), // an html element to display the video iceGatheringTimeout: 0.01, requestTimeout: 0.01, }); try { await roomSession.join(); } catch (error) { console.error("Error", error); } const cams = await SignalWire.WebRTC.getCameraDevicesWithPermissions(); const mics = await SignalWire.WebRTC.getMicrophoneDevicesWithPermissions(); // Pick the first camera in the list as the new video input device roomSession.updateCamera({ deviceId: cams[0].deviceId, }); // Pick the first microphone in the list as the new audio input device roomSession.updateMicrophone({ deviceId: mics[0].deviceId, }); ``` *Note that you don't explicitly have to update camera and microphone. SignalWire Video SDK chooses the preferred input devices by default on setup. Only `updateCamera` or `updateMicrophone` when you want to switch to a non-default device.*
