*** id: e3458a56-3f8b-4b1b-8a0e-d55a15bb17df description: 'Add high-quality, high-performance video to your application or website' x-custom: tags: * 'product:video' * 'sdk:relaybrowser' * 'language:javascript' * 'language:nodejs' sidebar\_custom\_props: platform: javascript slug: /js/guides/build-a-video-app title: Build a video calling application with the Browser SDK max-toc-depth: 3 *** SignalWire's Video API allows you to host real-time video calls and conferences on your website or app. In this guide, we will use SignalWire APIs in three steps to create a minimal full-stack video-calling website. This is what we will cover: 1. Registering with SignalWire to [obtain your API key and Project ID](#obtaining-your-api-key-and-project-id) 2. Writing a minimal [backend server](#backend) in Node.js. This is a simple proxy server, so if you prefer you can use any platform such as PHP or Python. 3. Developing a simple [frontend web app](#frontend) in JavaScript. The SignalWire Browser SDK will do most of the work for us. When the site is finished, it will look something like this: ![a video call with two participants and a button labeled 'Hang up' beneath the video.](https://files.buildwithfern.com/signalwire.docs.buildwithfern.com/docs/f9c255160c525b783dddc36c05137c4bf97749cd7962733d8491370fb9ddbffe/assets/images/project/simple-video-demo/video-room.webp) ## Obtaining your API key and Project ID First, we will need access to the SignalWire APIs. If you already have a SignalWire account, can [sign in to the SignalWire website](https://signalwire.com/signin). If you're not already registered, you can [**sign up**](https://signalwire.com/signups/new) in trial mode, which comes with a \$5 credit. This will be plenty to follow along with this guide. Once you've signed up and verified your email, create a new project. Next, navigate to the [API Credentials page](https://my.signalwire.com?page=credentials) page of your SignalWire Dashboard. ![The API page shows the active Project ID and Space URL, and a list of API tokens organized by Name, Token, and Last Used.](https://files.buildwithfern.com/signalwire.docs.buildwithfern.com/docs/1bb2912f8cedf2a1a781e7100ecfaefcb7cec50da1089510286103cbb63c0d89/assets/images/dashboard/credentials/api-credentials.webp) Two important pieces of information about our project are displayed there: * **Space URL:** You'll use this URL to access SignalWire APIs * **Project ID:** You'll use this UUID to specify your project to the API There is one more piece of information that we need from our new project. We need to generate an **API token** to access SignalWire's APIs from our own code. To generate an API token, click on the New Token button. Give it an easily identifiable name, and make sure that the **"Video" scope** is enabled. Then hit **"Save"**. It is important that the API tokens are not publically exposed. They can be used to make API requests on your behalf. Take extreme care to make sure that the tokens are not pushed to GitHub or exposed in frontend code. For Node.js backends, you can use [dotenv files](https://www.npmjs.com/package/dotenv) or similar mechanisms to safely store confidential constants. Now that we have collected the Project ID, the Space URL, and the API token, we can start writing our application. ## Backend ### Why do I need my own backend? As mentioned in the previous section, API tokens must be kept confidential. When you build a web application or any application that runs on a user's device, the code running on the device should be considered *untrusted* (secrets can be stolen). S ince you must use the API token from a *trusted* environment, you do so in your own server. Having your own backend server also allows you to build custom authorization policies instead of giving every client admin access. The figure below illustrates the typical network interaction we are building. Your server can directly access the SignalWire servers (for example, to get a list of active rooms). However, for a client to interact with SignalWire servers, it must first ask *your server* to provide a limited-scope token (we call this the *Video Room Token*).
```mermaid sequenceDiagram participant SW as SignalWire Servers participant YS as Your Server participant C as Client (Browser, App, ...) YS->>SW: GET list of rooms SW-->>YS: [Room A, Room B, Room C] C->>YS: GET Video Room Token for Room A YS->>SW: GET Video Room Token SW-->>YS: { Token } YS-->>C: { Token } C->>SW: Join Room A via RELAY Browser SDK SW-->>C: WebRTC Stream (Video & Events) C->>SW: Change Room Layout C->>SW: Mute Audio C->>SW: Leave Room ```
A diagram showing the relationship between SignalWire Servers, Your Server, and the Client, such as a browser or app. The SignalWire Servers communicate a list of rooms and the requested Video Room Token to Your Server. The Client interfaces with SignalWire Servers to join the room, transmit WebRTC video stream and events, and perform room actions like changing room layout, muting audio, and leaving the room.
The **API token** gives full access to SignalWire APIs. Whoever owns the API token can, for example, delete any room, mute or unmute any participant, and so on without limitations. You may only use the API token **in your server** to communicate with SignalWire. The **Video Room Token** is a limited-scope token that clients can use to access SignalWire APIs without knowing the API token. Clients must ask your proxy server for a Video Room Token. Your server will obtain it from SignalWire servers and pass it back to the client. Video Room Tokens are associated with a given `<_user_, _room_>` pair, so you can think of them as a personal key for a given user to access a given room. Your server sets the permissions for each Video Room Token, for example, whether they are allowed to mute other users. ### Getting a Video Room Token using cURL Let's take a look at how our backend will use the API token to get a Video Room Token. To get a token from the REST API for a user with name "john" and a room "office" with only video muting permissions, we can use this call: ```shell curl --request POST \ --url 'https://your_space_url.signalwire.com/api/video/room_tokens' \ --user 'project_id:api_token' \ --header 'Content-Type: application/json' \ --data '{"user_name": "john", "room_name": "office", "permissions": ["room.self.video_mute"]}' ``` You can see a complete list of possible [permissions](/docs/apis/permissions) and [video token parameters](/docs/apis/video/room-tokens/create-room-token) in our documentation. The JSON response from the API will look like this and can be safely sent to the client: ```json { "token": "eyJ0eXAiOiJWUlQiLCJhbGciOiJIUzUxMiJ9.eyJpYXQiOjE2MzI0OTE3ODAsImp0aSI6ImM2NmU3ODlkLTJmMjItMTIzNC1hNzMzLThlZjA2MzdmNWI2YiIsInN1YiI6ImExNmQ4ZjllLTIxNjYtNGU4Mi01Njc4LWE0ODQwZjIxN2JjMyIsInUiOiJqb2huIiwiciI6Im9mZmljZSIsInMiOlsicm9vbS5yZWNvcmRpbmciXSwiYWNyIjp0cnVlfQ.qYQwQ1PEnzGbAIb1RoVuYLf0mlqApi15wSC2n7QMCFP4M7jOjOIb_Ia_BhKnbnTHb7sI78d2jS7f_qsFV2OHLw" } ``` ### Getting a Video Room Token using your own server Instead of using `curl`, and to allow for more granular control over permissions alongside user authentication, we'll create a server to accept an incoming request for a Video Room Token, obtain the Video Room Token, and send it back to the client. Our server only needs to expose a single endpoint, which we will call `/get_token` (but it can be anything you want). ```javascript // Auth constants to be stored in a dotenv file (or equivalent) with gitignore const auth = { username: "xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxx", // Project ID password: "PTxxx...xxx", // API token }; const apiurl = "https:///api/video"; // Endpoint to request Video Room Token for video call app.post("/get_token", async (req, res) => { let { user_name, room_name } = req.body; console.log("Received name", user_name); try { // get the Video Room Token from SignalWire let token = await axios.post( apiurl + "/room_tokens", { user_name: user_name, room_name: room_name, permissions: [ "room.list_available_layouts", "room.set_layout", "room.self.audio_mute", "room.self.audio_unmute", "room.self.video_mute", "room.self.video_unmute", ], }, { auth } ); console.log(token.data.token); // send the Video Room Token back to the client return res.json({ token: token.data.token }); } catch (e) { console.log(e); return res.sendStatus(500); } }); ``` Let's break this piece of code down. 1. The user's `user_name` will be used to identify them in the video call, so the frontend will send this information when making a request to our `/get_token` endpoint. Likewise, the `room_name` determines the name of the room to join. If the room doesn't exist, it will be created automatically. 2. We send a post request to the `room_tokens` endpoint of SignalWire REST APIs. The `room_tokens` endpoint sends back a Video Room Token that we can forward to our client. Now we have everything we need to start building the frontend. ## Frontend The SignalWire Browser SDK makes it surprisingly easy to integrate video calling into any web application. It only takes a few minutes to set up the basics. First, we need to include the SDK in our HTML. ```html ``` Then you can interact with the SDK using the global variable `SignalWire`. We'll mainly be interested in the `SignalWire.Video.RoomSession` class for this guide, but if you'd like to explore this API, please browse the [SDK documentation](/docs/browser-sdk). Before a user can join a room, we need to make a POST request for a Video Room Token to the backend server endpoint we just created. ```javascript const backendurl = ""; // Your backend server. If you server and frontend are in the same directory, you can leave this string empty let token = await axios.post(backendurl + "/get_token", { user_name: username, room_name: roomname, }); console.log(token.data); token = token.data.token; ``` Then, to start the video session, we instantiate a new `RoomSession` object and then we join it: ```javascript roomSession = new SignalWire.Video.RoomSession({ token, rootElement: document.getElementById("root"), // The HTML element in which to display the video }); try { await roomSession.join(); } catch (error) { console.error("Error", error); } ``` The other important key-value parameter to pass is a `rootElement`. The root element is an empty HTML element in your DOM (for example, a \`\`). It will serve as the container for the video stream. When `roomSession.join` is called, the SDK will join the room, and the video will appear in `rootElement`. These pieces are all you need to get the video up and running. However, we can polish our application by using the Events included on the Room Session object. ### Using Events The Room Session object supports the standard `.on()` method to attach event listeners and the corresponding `.off()` method to detach them. **You should subscribe to events after the room is created but before joining the room.** Some of the events you might subscribe to are: * `room.joined`: you have joined the room * `room.updated`: a room property has been updated * `room.ended`: the room has ended * `member.updated`: a member property has changed (e.g., video muted) * `member.updated.audio_muted`: the audio\_muted state has changed for a member * `member.updated.video_muted`: the video\_muted state has changed for a member * `member.updated.visible`: the member is now visible in the video layout * `member.left`: a member left the room * `layout.changed`: the layout of the room has changed Find the complete list in our [API reference](/docs/browser-sdk/v3/js/reference/video/room-session/events). Here's how we can use some these events in our example program: ```javascript roomSession.on("room.joined", (e) => logevent("You joined the room")); roomSession.on("member.joined", (e) => logevent(e.member.name + " has joined the room")); roomSession.on("member.left", (e) => logevent(e.member.id + " has left the room")); ``` ### Putting it All Together All the above ideas can be combined to create the following function, which we'll use (with minor variations) in the frontend. ```javascript async function join() { const username = $("usernameinput").value.trim(); const roomname = $("roomnameinput").value.trim(); gotopage("loading"); try { token = await axios.post(backendurl + "/get_token", { user_name: username, room_name: roomname, }); console.log(token.data); token = token.data.token; try { try { roomSession = new SignalWire.Video.RoomSession({ token, rootElement: document.getElementById("root"), }); } catch (e) { console.log(e); } roomSession.on("room.joined", (e) => logevent("You joined the room")); roomSession.on("member.joined", (e) => logevent(e.member.name + " has joined the room") ); roomSession.on("member.left", (e) => logevent(e.member.id + " has left the room")); await roomSession.join(); } catch (error) { console.error("Something went wrong", error); } gotopage("videoroom"); } catch (e) { console.log(e); alert("Error encountered. Please try again."); gotopage("getusername"); } } ``` Please visit our [GitHub page](https://github.com/signalwire/guides/tree/main/Video/Simple%20Video%20Demo) to see complete code or fork the repository. ## Conclusion Here is the final result of our development with a preview of some added features: ![SignalWire video call with controls for screen share, layout, audio, and video.](https://files.buildwithfern.com/signalwire.docs.buildwithfern.com/docs/38f2807b3e2856f531125e21f5a9fbc87896c780e9cdcb8bc745e2b501173d58/assets/images/project/simple-video-demo/video-room-final.webp) The most noteworthy thing about SignalWire Video technology is that it only streams a single video stream no matter how many participants there are. The video is composited on powerful SignalWire servers by stitching all of the individual video streams together. So you can invite as many people as you like to your virtual video party. Your app will run without a hitch. **What now?** If you would like a custom approach that adds to what we developed here, visit one of our guides below. If you prefer a guide to build a standard, polished video application from scratch, you can see our [Zoom like application Guide](/docs/browser-sdk/v3/js/guides/zoom-like-application).
