# Migrate from v3
This guide walks through moving an existing v3 (`@signalwire/js@3.x`) integration to v4. v3 was built around `RoomSession` and event emitters for video conferencing. v4 unifies calling and conferencing under a single `Call` API, replaces event emitters with RxJS observables, and introduces a credential-provider auth model with automatic token refresh.
## At a glance
| Concern         | v3                                                            | v4        |
| Initialization  | `await SignalWire({ host, token })` (async factory)           | `new SignalWire(credentialProvider)` (class constructor)                            |
| Authentication  | Token passed directly                                         | `CredentialProvider` with auto-refresh (`StaticCredentialProvider`, custom)         |
| State           | Event emitters — `roomObj.on('event', handler)`               | RxJS observables — `call.status$.subscribe(handler)`                                |
| Call controls   | `roomObj.audioMute()`, `roomObj.videoMute()`                  | `call.self.toggleMute()`, `call.self.toggleMuteVideo()`                             |
| Media rendering | `rootElement` passed to `dial()` — SDK manages the DOM        | `<sw-call-media>` / `<sw-self-media>` components, or `localStream$`/`remoteStream$` |
| Devices         | `getCameraDevicesWithPermissions()`, `roomObj.updateCamera()` | `client.audioInputDevices$`, `self.selectAudioInputDevice()`                        |
| Directory       | Paginated API — `client.address.getAddresses({...})`          | Observable directory — `client.directory.addresses$`, `loadMore()`                  |
| Inbound calls   | `client.online({ incomingCallHandlers })`                     | `client.session.incomingCalls$` (always active after register)                      |
| Messaging       | `client.conversation.sendMessage()` / `subscribe()`           | `callAddress.sendText()` / `callAddress.textMessages$`                              |
## Feature compatibility
v4 covers the bulk of v3, but some features are still in progress. Check this table before migrating.
| Feature               | v4 Status       | Alternative                  |
| Video rooms & calling | Implemented     | —                            |
| Participants & events | Implemented     | —                            |
| Layouts               | Implemented     | —                            |
| Screen sharing        | Implemented     | —                            |
| Mute/unmute           | Implemented     | —                            |
| Device selection      | Implemented     | —                            |
| DTMF                  | Implemented     | —                            |
| Hold/unhold           | Implemented     | —                            |
| Recording             | Not implemented | Use SWML or the REST API     |
| Streaming (RTMP)      | Not implemented | Use the server-side REST API |
| Playback              | Not implemented | Use SWML                     |
| Room locking          | Not implemented | —                            |
| Metadata (`setMeta`)  | Not implemented | —                            |
| Call transfer         | Not implemented | —                            |
If your application depends on recording, streaming, playback, room locking, metadata, or transfer, wait for these features to land before migrating.
## Migration checklist
* [ ] Update the package and import paths
* [ ] Replace `await SignalWire({ token })` with `new SignalWire(credentialProvider)`
* [ ] Remove `rootElement` from `dial()` and attach media streams manually (or use web components)
* [ ] Drop `node_id` / `userVariables` / `await call.start()` — handled by v4 internally
* [ ] Convert `RoomSession` methods to `Call` / `call.self` equivalents
* [ ] Replace `roomObj.on('event', ...)` with `call.eventName$.subscribe(...)`
* [ ] Update `invite.accept` / `invite.reject` to `call.answer()` / `call.reject()`
* [ ] Drop `client.online()` / `client.offline()` — registration is automatic (use `client.unregister()` to go offline)
* [ ] Move screen share from the room to `call.self`
* [ ] Swap `WebRTC.getCameras()` etc. for `client.videoInputDevices$`
* [ ] Pass full `MediaDeviceInfo` objects (not bare `deviceId`) to device selectors
* [ ] Replace `client.address.getAddresses()` with `client.directory.addresses$`
* [ ] Replace `client.conversation` messaging with `callAddress.sendText()` / `textMessages$`
* [ ] Add explicit cleanup: `call.hangup()`, `client.disconnect()`, `client.destroy()`
## Installation
The package name is unchanged. Upgrade to the v4 major release:
```bash
npm install @signalwire/js@latest
For the browser build:
```html
<script src="https://cdn.jsdelivr.net/npm/@signalwire/js/dist/browser.umd.js"></script>
v4 ships as an ES module. If you bundled v3 as a CDN global, switch to module imports:
```html
<!-- v3: CDN global -->
<script src="https://unpkg.com/@signalwire/client@dev"></script>
<!-- v4: bundled ES module -->
<script type="module" src="/src/main.js"></script>
```js
## Authentication
v3 accepted a room token directly. v4 introduces a **CredentialProvider** that owns the token lifecycle — including scheduled refresh before expiry. Use **Subscriber Access Tokens (SAT)** for authenticated users and **Embed Tokens** for guest access. See [Authentication](/docs/browser-sdk/v4/guides/authentication) for the full reference.
The SDK ships with `StaticCredentialProvider` for pre-obtained tokens (build-time SAT, server-rendered pages). For long-running apps, implement a custom provider that fetches and refreshes a SAT from your backend.
### Client Bound SAT (DPoP)
When the SDK passes an `AuthenticateContext` with a DPoP key `fingerprint`, forward it to your token endpoint to request a **Client Bound SAT** with automatic refresh:
```js
class UserCredentialProvider {
  async authenticate(context) {
    const response = await fetch("/api/subscriber/token", {
      method: "POST",
      headers: { "Content-Type": "application/json" },
      body: JSON.stringify({ fingerprint: context?.fingerprint }),
    const { token, expiresAt } = await response.json();
    return { token, expiry_at: expiresAt };
  async refresh() {
    return this.authenticate();
## Client initialization
v3 was an async factory. v4 is a synchronous constructor; connection happens automatically when you subscribe to the first observable.
**Before (v3):**
```js
  host,
  token: "<TOKEN>",
  debug: { logWsTraffic: true },
**After (v4):**
```js
const credentials = new StaticCredentialProvider({ token: "<TOKEN>" });
// Second argument carries v3-style options (debug, logLevel, custom logger, etc.)
const client = new SignalWire(credentials, {
  logLevel: "debug",
client.ready$.subscribe((ready) => {
  if (ready) console.log("Client connected and authenticated");
client.errors$.subscribe((error) => {
  console.error("Client error:", error);
By default, the client connects and registers automatically on construction. Pass `skipConnection: true` or `skipRegister: true` if you want to drive that lifecycle yourself.
### Connection state
v3 had no separate connection observable — the factory was the connect call. v4 exposes connection state reactively:
```js
client.isConnected$.subscribe((connected) => { /* ... */ });
client.isRegistered$.subscribe((registered) => { /* ... */ });
client.ready$.subscribe((ready) => { /* connected + authenticated */ });
## Outbound calls
v3 took an options object with `to`, `rootElement`, optional `nodeId` for routing, and `userVariables`, then required `await call.start()`. v4 takes the destination as the first argument, handles steering internally, and does **not** auto-attach media — you wire streams up yourself.
**Before (v3):**
```js
const call = await client.dial({
  to: "/private/user1",
  rootElement: document.getElementById("container"),
  nodeId: steeringId,
  userVariables: { /* ... */ },
await call.start();
**After (v4):**
```js
const call = await client.dial("/private/user1", {
  audio: true,
  video: true,
// No rootElement, no nodeId, no start() — routing is internal
call.remoteStream$.subscribe((stream) => {
  if (stream) document.getElementById("remoteVideo").srcObject = stream;
call.localStream$.subscribe((stream) => {
  if (stream) document.getElementById("localVideo").srcObject = stream;
### Full call lifecycle
```js
// v3
const call = await client.dial({ to, rootElement, nodeId, userVariables });
await call.start();
roomObj.on("room.joined", handler);
roomObj.on("media.connected", handler);
roomObj.hangup();
// v4
const call = await client.dial(address, { audio, video });
call.status$.subscribe(handler);          // replaces on('room.joined')
call.localStream$.subscribe(/* ... */);   // replaces rootElement auto-render
call.remoteStream$.subscribe(/* ... */);
call.hangup();
## Inbound calls
v3 used `client.online({ incomingCallHandlers })` with callbacks and an explicit `offline()`. v4 registers the user automatically on construction and exposes incoming calls as an observable — no online/offline toggle. To go offline for inbound calls, call `client.unregister()` (and `client.register()` to come back online). `answer()` and `reject()` are **synchronous** in v4 — no `await` needed.
**Before (v3):**
```js
await client.online({
  incomingCallHandlers: {
    all: (notification) => {
      window.__invite = notification.invite;
const call = await window.__invite.accept({
await window.__invite.reject();
await client.offline();
**After (v4):**
```js
// Registration happens automatically on client construction.
client.session.incomingCalls$.subscribe((calls) => {
  const ringing = calls.filter((c) => c.status === "ringing");
  if (ringing.length > 0) showIncomingCallUI(ringing[0]);
function acceptCall(call) {
  call.answer(); // synchronous
function rejectCall(call) {
  call.reject(); // synchronous
// Equivalent to v3's client.offline() / client.online()
await client.unregister();
await client.register();
## RoomSession → Call
v3 distinguished between `CallFabricRoomSession` and `RoomSession`. v4 collapses both into a single `Call`, with self-participant controls moved off the room object onto `call.self`.
| v3                                            | v4                                      |
| `roomSession.audioMute()`                     | `call.self.mute()`                      |
| `roomSession.audioUnmute()`                   | `call.self.unmute()`                    |
| `roomSession.videoMute()`                     | `call.self.muteVideo()`                 |
| `roomSession.videoUnmute()`                   | `call.self.unmuteVideo()`               |
| `roomSession.deaf()`                          | `call.self.toggleDeaf()`                |
| `roomSession.startScreenShare()`              | `call.self.startScreenShare()`          |
| `roomSession.stopScreenShare()`               | `call.self.stopScreenShare()`           |
| `roomSession.setMicrophoneVolume({ volume })` | `call.self.setAudioInputVolume(value)`  |
| `roomSession.setSpeakerVolume({ volume })`    | `call.self.setAudioOutputVolume(value)` |
## Self participant
`call.self` is a full participant object with reactive state.
```js
const self = call.self;
await self.mute();
await self.unmute();
await self.toggleMute();
await self.muteVideo();
await self.unmuteVideo();
await self.toggleMuteVideo();
await self.toggleDeaf();
// Sync access
const isMuted = call.self?.audioMuted;
const isVideoMuted = call.self?.videoMuted;
// Reactive
call.self$.subscribe((self) => {
  if (self) {
    self.audioMuted$.subscribe((muted) => updateMuteButton(muted));
## Participants
Event emitters are gone — participants are an observable list. Each participant also exposes individual observables for granular updates.
**Before (v3):**
```js
roomSession.on("member.joined", (member) => addParticipantToUI(member));
roomSession.on("member.left", (member) => removeParticipantFromUI(member));
roomSession.on("member.updated", handler);
const members = roomSession.members; // flat objects with properties
**After (v4):**
```js
// Full list (re-emits on every change)
call.participants$.subscribe((participants) => {
  renderParticipantList(participants);
// Individual events
call.memberJoined$.subscribe((event) => addParticipantToUI(event.member));
call.memberLeft$.subscribe((event) => removeParticipantFromUI(event.member_id));
// Per-participant observables for fine-grained UI updates:
//   participant.name$
//   participant.audioMuted$
//   participant.videoMuted$
//   participant.isTalking$
//   participant.handraised$
//   participant.deaf$
//   participant.visible$
//   participant.position$
const participants = call.participants;
## Screen sharing
Screen sharing moves from the room to `call.self`.
```js
await call.self.startScreenShare();
await call.self.stopScreenShare();
  if (self) {
    self.screenShareStatus$.subscribe((status) => {
      console.log("Screen share:", status);
## Layouts
```js
// v3
roomObj.getLayoutList();
roomObj.setLayout({ name: layoutName });
roomObj.on("layout.changed", (event) => console.log(event.layout));
// v4
call.layouts$.subscribe((layouts) => console.log("Available:", layouts));
call.layout$.subscribe((layout) => console.log("Current:", layout));
await call.setLayout("grid", {});
await call.setLayout("highlight-1-active-4", {
  "participant-id": "reserved-1",
## Recording and streaming
Recording and streaming APIs are **not yet implemented** in v4. The observables exist for monitoring server-initiated state, but `startRecording()` and `startStreaming()` will throw. Drive these from SWML or the server-side REST API in the meantime.
```js
// State observable (for server-initiated recordings)
call.recording$.subscribe((isRecording) => updateRecordingIndicator(isRecording));
const isRecording = call.recording;
## Device management
The standalone `WebRTC` namespace and `roomObj.updateCamera()`-style methods are removed. Devices live on the client as reactive lists that auto-update when devices are plugged in or removed.
> **Heads up:** v4 device selectors take the full `MediaDeviceInfo` object, not just a `deviceId` string.
**Before (v3):**
```js
import { WebRTC } from "@signalwire/js";
enumerateDevices();
getCameraDevicesWithPermissions();
createDeviceWatcher(); // for change detection
await WebRTC.getCameras();
await WebRTC.getMicrophones();
await WebRTC.getSpeakers();
await WebRTC.checkCameraPermissions();
roomObj.updateMicrophone({ deviceId });
roomObj.updateCamera({ deviceId });
**After (v4):**
```js
client.videoInputDevices$.subscribe((cameras) => populateCameraSelect(cameras));
client.audioInputDevices$.subscribe((mics) => populateMicSelect(mics));
client.audioOutputDevices$.subscribe((speakers) => populateSpeakerSelect(speakers));
// Pass the full MediaDeviceInfo, not just deviceId
call.self.selectVideoInputDevice(deviceInfo);
call.self.selectAudioInputDevice(deviceInfo);
call.self.selectAudioOutputDevice(deviceInfo);
// Sync access
const cameras = client.videoInputDevices;
## User info
`Subscriber` is renamed to `User`.
**Before (v3):**
```js
const info = await client.getSubscriberInfo();
console.log("Logged in as:", info.name);
**After (v4):**
```js
const user = client.user;
user.fetched$.subscribe((fetched) => {
  if (fetched) {
    console.log("User ID:", user.id);
    console.log("Display name:", user.displayName);
## Directory
v3's paginated `client.address.getAddresses()` is replaced by a reactive directory that accumulates entries on `loadMore()`.
**Before (v3):**
```js
const data = await client.address.getAddresses({
  type,
  displayName,
  pageSize: 10,
// data.data, data.hasNext, data.hasPrev, data.nextPage(), data.prevPage()
**After (v4):**
```js
const directory = client.directory;
directory.addresses$.subscribe((addresses) => {
  // Reactive list — accumulates as loadMore() is called
  addresses.forEach((addr) => console.log(addr.displayName, addr.type));
directory.hasMore$.subscribe((hasMore) => toggleLoadMoreButton(hasMore));
directory.loading$.subscribe((loading) => showSpinner(loading));
directory.loadMore(); // fetches and appends the next page
You can dial an address directly:
```js
const address = client.directory.addresses.find((a) => a.name === "user1");
const call = await client.dial(address.defaultChannel, { video: true, audio: true });
// URI strings still work
const call2 = await client.dial("/private/user1");
## Messaging
v3's `client.conversation` API is replaced by per-address messaging on the call.
**Before (v3):**
```js
client.conversation.sendMessage({ addressId, text });
client.conversation.subscribe((newMsg) => { /* ... */ });
client.conversation.getConversationMessages({ addressId, pageSize });
**After (v4):**
```js
callAddress.sendText(text); // scoped to the call's address
callAddress.textMessages$.subscribe((textMessagesCollection) => {
  textMessagesCollection.values$.subscribe((messages) => renderMessages(messages));
  textMessagesCollection.hasMore$.subscribe((hasMore) => {});
  textMessagesCollection.loadMore();
Messages are scoped to the current call's address — there is no global conversation client in v4.
## Removed namespaces
The standalone `Chat`, `PubSub`, and `WebRTC` clients from v3 are removed. Device APIs move onto the client (see [Device management](#device-management)). Chat/PubSub equivalents are not part of the v4 browser SDK.
## Event-to-observable reference
> When using RxJS operators like `filter`, `map`, or `pipe`, import them from `rxjs`:
> ```js
> import { filter, map } from "rxjs";
> See the [RxJS primer](/docs/browser-sdk/v4/guides/rxjs-primer) for a quick orientation.
| v3 Event                  | v4 Observable                                          |
| `member.joined`           | `call.memberJoined$`                                   |
| `member.left`             | `call.memberLeft$`                                     |
| `member.updated`          | `call.memberUpdated$`                                  |
| `member.talking`          | `call.memberTalking$`                                  |
| `layout.changed`          | `call.layout$`, `call.layoutLayers$`                   |
| `recording.started/ended` | `call.recording$` (state observable)                   |
| `playback.started/ended`  | Not available in the browser SDK (server-side only)    |
| `room.updated`            | `call.meta$`, `call.locked$`                           |
| `room.joined`             | `call.status$.pipe(filter(s => s === 'connected'))`    |
| `room.left`               | `call.status$.pipe(filter(s => s === 'disconnected'))` |
## API quick reference
| v3                                            | v4                                                            |
| `SignalWire({ token })`                       | `new SignalWire(credentialProvider)`                          |
| Ready callback                                | `client.ready$` (emits `true` when connected + authenticated) |
| `client.dial({ to, rootElement })`            | `client.dial(destination, options)`                           |
| `client.online({ handlers })`                 | Automatic — subscribe to `client.session.incomingCalls$`      |
| `client.offline()`                            | `client.unregister()` (re-enable with `client.register()`)    |
| `invite.accept()` (async)                     | `call.answer()` (sync)                                        |
| `invite.reject()` (async)                     | `call.reject()` (sync)                                        |
| `roomSession.setLayout(name)`                 | `call.setLayout(name, positions)`                             |
| `roomSession.getLayoutList()`                 | `call.layouts$`                                               |
| `roomSession.members`                         | `call.participants` / `call.participants$`                    |
| `roomSession.on('event', fn)`                 | `call.eventName$.subscribe(fn)`                               |
| `client.updateToken(token)`                   | Handled by credential provider's `refresh()`                  |
| `client.address.getAddresses()`               | `client.directory.addresses$` + `directory.loadMore()`        |
| `client.conversation.sendMessage()`           | `callAddress.sendText()`                                      |
| `roomSession.leave()`                         | `call.hangup()`                                               |
| Disconnect                                    | `client.disconnect()` + `client.destroy()`                    |
## Cleanup
v4 requires explicit cleanup. End calls with `hangup()`, then disconnect and destroy the client to release all subscriptions.
```js
await call.hangup();
await client.disconnect(); // closes the WebSocket
client.destroy();          // releases subscriptions and resources
// Manual subscription cleanup, if needed
const sub = call.status$.subscribe((status) => console.log(status));
sub.unsubscribe();
## Web components
v4 ships `@signalwire/web-components`, composable around the new reactive Call API. `<sw-call-media>` is the root container — nest media, controls, and status components inside, then assign the call.
```html
<script type="module">
  import "@signalwire/web-components";
</script>
<sw-call-media id="call-media">
  <sw-self-media mirror></sw-self-media>
  <sw-call-controls></sw-call-controls>
  <sw-call-status></sw-call-status>
</sw-call-media>
```js
const call = await client.dial("/public/room");
const callMedia = document.getElementById("call-media");
callMedia.call = call;
// Child components receive the call automatically via Lit context
`<sw-participants>` renders participant overlays driven by the same context.
## Common migration issues
1. **No video displays.** v4 does not auto-attach to the DOM. Subscribe to `remoteStream$` (and `localStream$`) and assign the stream to a `<video>`'s `srcObject` — or use `<sw-call-media>` / `<sw-self-media>`.
2. **`call.self` is null.** `self` is populated only after joining. Use `call.self$` for reactive access, or optional chaining (`call.self?.audioMuted`) for sync reads.
3. **Events seem to be missing.** Subscribe to observables before the events fire — and avoid unsubscribing prematurely. `participants$` re-emits the full list on any change, so wire it up early in your component lifecycle.
4. **`startRecording()` throws.** Recording is not yet implemented in v4. Trigger recording server-side via SWML or the REST API; use `call.recording$` to reflect state in the UI.
5. **Device selection has no effect.** v4 expects a full `MediaDeviceInfo` object, not a bare `deviceId` string.
6. **Token expired errors after a while.** v3's `client.updateToken()` is gone. Implement `refresh()` on your credential provider and return `{ token, expiry_at }` — the SDK will refresh on schedule.
