# Device Management
To let users pick which microphone, camera, and speaker a call uses, subscribe to the device lists, render a picker, and apply the user's choice — either as a preference for the next call or as a live swap during one. The same APIs cover hot-plug events, so a new headset shows up in the list as soon as it's connected.
```ts Browser
const client = new SignalWire(new StaticCredentialProvider({ token: SAT }));
// 1. Prompt for permission so devices come back with real labels.
await client.requestMediaPermissions({ audio: true, video: true });
// 2. Render the lists; they re-emit when devices are plugged or unplugged.
client.audioInputDevices$.subscribe((mics) => renderMicOptions(mics));
client.videoInputDevices$.subscribe((cams) => renderCamOptions(cams));
client.audioOutputDevices$.subscribe((speakers) => renderSpeakerOptions(speakers));
// 3. Apply the user's choice. Before a call, set the preference on the client;
//    during a call, switch the live track on `call.self`.
micSelect.onchange = () => {
  const mic = client.audioInputDevices.find((d) => d.deviceId === micSelect.value);
  if (activeCall?.self) activeCall.self.selectAudioInputDevice(mic);
  else client.selectAudioInputDevice(mic);
The sections below cover requesting permission, reading the device lists, applying the user's pick before a call and again mid-call, routing remote audio to the chosen speaker, and reacting when a device disappears.
**Before you start.** Devices live behind the browser's permission gate. `getUserMedia` only runs on secure origins (HTTPS or `localhost`), and device labels are empty strings until the user has granted access at least once. Plan the UX so picking a device comes *after* the prompt — not the other way around.
## The three device kinds
Each kind comes with its own pair of observables: one for the list of available devices, and one for the current selection. Subscribe to both whenever you render a picker so the `<select>` reflects what's actually in use — including changes that happen without an explicit user pick, such as a recovery after the active device was unplugged.
#### Microphones
[`audioInputDevices$`](/docs/browser-sdk/v4/reference/signalwire/audio-input-devices\$) lists every mic; [`selectedAudioInputDevice$`](/docs/browser-sdk/v4/reference/signalwire/selected-audio-input-device\$) tracks the current pick.
#### Cameras
[`videoInputDevices$`](/docs/browser-sdk/v4/reference/signalwire/video-input-devices\$) lists every camera; [`selectedVideoInputDevice$`](/docs/browser-sdk/v4/reference/signalwire/selected-video-input-device\$) tracks the current pick.
#### Speakers
[`audioOutputDevices$`](/docs/browser-sdk/v4/reference/signalwire/audio-output-devices\$) lists every speaker; [`selectedAudioOutputDevice$`](/docs/browser-sdk/v4/reference/signalwire/selected-audio-output-device\$) tracks the current pick.
When you only need the current snapshot — for example, populating a dropdown once on click — read the non-`$` accessor instead: `client.audioInputDevices`, `client.videoInputDevices`, `client.audioOutputDevices`. Use the observable when the UI should keep up with hot-plugs and SDK-driven switches.
## Prompt for permission
Each list populates from `navigator.mediaDevices.enumerateDevices()`. Until the user grants permission, that call returns devices with empty `label` strings, which makes a picker UI useless. Call [`requestMediaPermissions()`](/docs/browser-sdk/v4/reference/signalwire/request-media-permissions) once at startup to drive the prompt and re-enumerate with labels filled in:
```ts Browser
const result = await client.requestMediaPermissions({ audio: true, video: true });
if (!result.audio || !result.video) {
  showPermissionBanner("Allow microphone and camera in your browser to continue.");
The returned [`PermissionResult`](/docs/browser-sdk/v4/reference/interfaces/permission-result) reports which scopes were granted and which device the browser handed back for each kind. Those devices become the initial selection unless you've already set a preference. The browser only shows the prompt the first time per origin; later calls resolve immediately with the existing grant.
If the user denies the prompt, `enumerateDevices()` still returns the device list, but with empty labels. Show a "permission needed" banner instead of an empty dropdown, and link to the browser's lock-icon controls so they can grant it later.
## Read the device lists
Each list is an observable of `MediaDeviceInfo[]`. Subscribe once at startup — every subscription receives the current list immediately and then again whenever the OS reports a change. Pair the list with the matching `selected…$` observable so a `<select>` reflects the right value when the SDK switches devices on its own:
```ts Browser
let mics = [];
let selectedMic = null;
function renderMics() {
  micSelect.innerHTML = "";
  for (const mic of mics) {
    const option = new Option(mic.label || `Microphone ${mic.deviceId.slice(0, 6)}`, mic.deviceId);
    option.selected = mic.deviceId === selectedMic?.deviceId;
    micSelect.append(option);
client.audioInputDevices$.subscribe((list) => {
  mics = list;
  renderMics();
client.selectedAudioInputDevice$.subscribe((device) => {
  selectedMic = device;
  renderMics();
The same pattern fits `videoInputDevices$` and `audioOutputDevices$` — only the property names change. Caching the latest of each list in module-scope state keeps the rendering pure and avoids pulling in observable combinators.
## Apply the user's choice
There are two scopes for "use this device." Match the scope to the moment the user picks:
#### Before a call
Set a preference on the client. The selection sticks for every future [`dial()`](/docs/browser-sdk/v4/reference/signalwire/dial) and [`answer()`](/docs/browser-sdk/v4/reference/interfaces/call), so the next outbound call is captured from the right mic and camera without any extra wiring. Wire the picker's `change` event to look up the chosen `MediaDeviceInfo` from the live list and pass it to [`selectAudioInputDevice()`](/docs/browser-sdk/v4/reference/signalwire/select-audio-input-device) or [`selectVideoInputDevice()`](/docs/browser-sdk/v4/reference/signalwire/select-video-input-device):
```ts Browser
// <select id="mic-select"> populated from client.audioInputDevices$
    (d) => d.deviceId === micSelect.value,
  // null clears the preference and falls back to the system default.
  client.selectAudioInputDevice(mic ?? null);
camSelect.onchange = () => {
  const camera = client.videoInputDevices.find(
    (d) => d.deviceId === camSelect.value,
  client.selectVideoInputDevice(camera ?? null);
// Subsequent dials use the preference automatically.
const call = await client.dial("/private/alice", { audio: true, video: true });
The next `dial()` captures from the chosen mic and camera with no extra arguments. To change the default back later, look up a new device the same way, or pass `null` to clear the preference.
#### During a call
Replace the live track on [`call.self`](/docs/browser-sdk/v4/reference/self-participant). The user hears or sees the new device immediately, without renegotiation, and the remote side doesn't notice the switch. The shape is the same picker handler — only the target changes from `client` to `activeCall.self`:
```ts Browser
// While a call is in progress, swap the live track instead of setting
// a preference for the next call.
  if (!mic) return;
  // `savePreference: true` also stores the pick at the client level so
  // the next session starts with the same device selected.
  activeCall.self.selectAudioInputDevice(mic, { savePreference: true });
  if (!camera) return;
  activeCall.self.selectVideoInputDevice(camera, { savePreference: true });
See [`call.self.selectAudioInputDevice()`](/docs/browser-sdk/v4/reference/self-participant/select-audio-input-device) and [`call.self.selectVideoInputDevice()`](/docs/browser-sdk/v4/reference/self-participant/select-video-input-device) for the full options object — `constraints` and `savePreference` round out the supported keys.
In practice, a single picker handler covers both scopes — fall through to the client-level preference when there's no active call, replace the live track when there is:
```ts Browser
let activeCall = null;
function pickMicrophone(): void {
  if (!mic) return;
  if (activeCall?.self) {
    // Live swap; mid-call only.
  } else {
    // Preference for the next dial()/answer().
micSelect.onchange = pickMicrophone;
// Keep `activeCall` in sync with whatever call the user is on right now.
client.dial("/private/alice").then((call) => {
  activeCall = call;
  call.status$.subscribe((s) => {
    if (s === "destroyed") activeCall = null;
Speakers follow a slightly different path — see the next section.
## Route remote audio to the chosen speaker
Selecting a speaker takes an extra step the other devices don't — most browsers route audio output through the `<video>` or `<audio>` element the remote stream is attached to, and switching the sink is an element-level call. [`applySelectedAudioOutputDevice()`](/docs/browser-sdk/v4/reference/signalwire/apply-selected-audio-output-device) wraps `HTMLMediaElement.setSinkId()` so you don't have to:
```ts Browser
client.selectAudioOutputDevice(speaker);
const applied = await client.applySelectedAudioOutputDevice(remoteVideo);
if (!applied) {
  // Browser doesn't support setSinkId — fall through to the system default.
The method returns `true` when the sink was changed and `false` when no speaker is selected or the browser doesn't support `setSinkId`. Call it once after binding the remote stream to the element, and again any time the user picks a new speaker.
**Firefox doesn't ship `setSinkId` yet.** `applySelectedAudioOutputDevice()` returns `false` on Firefox and audio plays through the system default speaker. Check the return value and surface a "speaker selection unavailable" notice rather than silently swallowing the choice — see [the MDN compatibility table](https://developer.mozilla.org/en-US/docs/Web/API/HTMLMediaElement/setSinkId#browser_compatibility).
## React to device changes
Hot-plug events are already covered by the list observables — adding a USB headset re-emits `audioInputDevices$` with the new entry. What you usually want on top of that is a notification when the SDK *automatically switches* a device because the previous one was unplugged. Subscribe to [`deviceRecovered$`](/docs/browser-sdk/v4/reference/signalwire/device-recovered\$):
```ts Browser
client.deviceRecovered$.subscribe((event) => {
  toast(`${event.kind} switched to ${event.newDevice?.label ?? "system default"}`);
The [`DeviceRecoveryEvent`](/docs/browser-sdk/v4/reference/interfaces/device-recovery-event) carries everything you need to compose that notification:
| Field            | What it tells you        |
| `kind`           | Which kind switched: `audioinput`, `videoinput`, or `audiooutput`                       |
| `previousDevice` | The device that was active before the swap (may be `null` if it was unplugged)          |
| `newDevice`      | The device the SDK switched to (may be `null` if it fell back to the system default)    |
| `reason`         | Why: `device_disconnected`, `device_reconnected`, `fallback_to_default`, and a few more |
Reach for it when the user should know "we lost your AirPods and put you on the built-in mic" rather than discovering it mid-sentence.
Device monitoring is on by default. Use [`disableDeviceMonitoring()`](/docs/browser-sdk/v4/reference/signalwire/disable-device-monitoring) and [`enableDeviceMonitoring()`](/docs/browser-sdk/v4/reference/signalwire/enable-device-monitoring) to pause and resume it — handy on mobile when the page goes into the background and you don't want hot-plug events firing while the user can't see the UI.
## Try it: enumerate and switch devices
The fastest way to see the device APIs end-to-end is a single page that wires the three observable lists to three `<select>` elements, dials a test destination on demand, and switches the mic, camera, or speaker on the live call from the same picker. The handler routes preference changes through `client.*` before the call and live-track swaps through `activeCall.self.*` while the call is up — so the same dropdowns exercise both branches of the [Apply the user's choice](#apply-the-users-choice) section.
### Issue a Subscriber Access Token
Create a SAT for your project — the [Authentication guide](/docs/browser-sdk/v4/guides/authentication) covers the production version of this flow; the [Create Subscriber Token](/docs/apis/rest/subscribers/tokens/create-subscriber-token) reference sends the request for you.
### Request
POST https\://%7BYour\_Space\_Name%7D.signalwire.com/api/fabric/subscribers/tokens
```curl
curl -X POST https://{your_space_name}.signalwire.com/api/fabric/subscribers/tokens \
     -d '{
  "reference": "john.doe@example.com"
import requests
url = "https://{your_space_name}.signalwire.com/api/fabric/subscribers/tokens"
payload = { "reference": "john.doe@example.com" }
headers = {
response = requests.post(url, json=payload, headers=headers, auth=("<project_id>", "<api_token>"))
print(response.json())
```javascript
const url = 'https://{your_space_name}.signalwire.com/api/fabric/subscribers/tokens';
const credentials = btoa("<project_id>:<api_token>");
const options = {
  method: 'POST',
  headers: {
    Authorization: `Basic ${credentials}`,
    'Content-Type': 'application/json'
  body: '{"reference":"john.doe@example.com"}'
  const response = await fetch(url, options);
  const data = await response.json();
  console.log(data);
} catch (error) {
  console.error(error);
```go
package main
import (
	"fmt"
	"strings"
	"net/http"
	"io"
func main() {
	url := "https://{your_space_name}.signalwire.com/api/fabric/subscribers/tokens"
	payload := strings.NewReader("{\n  \"reference\": \"john.doe@example.com\"\n}")
	req, _ := http.NewRequest("POST", url, payload)
	req.SetBasicAuth("<project_id>", "<api_token>")
	req.Header.Add("Content-Type", "application/json")
	res, _ := http.DefaultClient.Do(req)
	defer res.Body.Close()
	body, _ := io.ReadAll(res.Body)
	fmt.Println(res)
	fmt.Println(string(body))
```ruby
require 'uri'
require 'net/http'
url = URI("https://{your_space_name}.signalwire.com/api/fabric/subscribers/tokens")
http = Net::HTTP.new(url.host, url.port)
http.use_ssl = true
request = Net::HTTP::Post.new(url)
request.basic_auth("<project_id>", "<api_token>")
request["Content-Type"] = 'application/json'
request.body = "{\n  \"reference\": \"john.doe@example.com\"\n}"
response = http.request(request)
puts response.read_body
```java
HttpResponse<String> response = Unirest.post("https://{your_space_name}.signalwire.com/api/fabric/subscribers/tokens")
  .basicAuth("<project_id>", "<api_token>")
  .header("Content-Type", "application/json")
  .body("{\n  \"reference\": \"john.doe@example.com\"\n}")
  .asString();
```php
<?php
require_once('vendor/autoload.php');
$client = new \GuzzleHttp\Client();
$response = $client->request('POST', 'https://{your_space_name}.signalwire.com/api/fabric/subscribers/tokens', [
  'body' => '{
  'headers' => [
    'Content-Type' => 'application/json',
    'auth' => ['<project_id>', '<api_token>'],
echo $response->getBody();
```csharp
using RestSharp;
using RestSharp.Authenticators;
var client = new RestClient("https://{your_space_name}.signalwire.com/api/fabric/subscribers/tokens");
client.Authenticator = new HttpBasicAuthenticator("<project_id>", "<api_token>");
var request = new RestRequest(Method.POST);
request.AddHeader("Content-Type", "application/json");
request.AddParameter("application/json", "{\n  \"reference\": \"john.doe@example.com\"\n}", ParameterType.RequestBody);
IRestResponse response = client.Execute(request);
```swift
import Foundation
let credentials = Data("<project_id>:<api_token>".utf8).base64EncodedString()
let headers = [
  "Authorization": "Basic \(credentials)",
let parameters = ["reference": "john.doe@example.com"] as [String : Any]
let postData = JSONSerialization.data(withJSONObject: parameters, options: [])
let request = NSMutableURLRequest(url: NSURL(string: "https://{your_space_name}.signalwire.com/api/fabric/subscribers/tokens")! as URL,
                                        cachePolicy: .useProtocolCachePolicy,
                                    timeoutInterval: 10.0)
request.httpMethod = "POST"
request.allHTTPHeaderFields = headers
request.httpBody = postData as Data
let session = URLSession.shared
let dataTask = session.dataTask(with: request as URLRequest, completionHandler: { (data, response, error) -> Void in
  if (error != nil) {
    print(error as Any)
  } else {
    let httpResponse = response as? HTTPURLResponse
    print(httpResponse)
dataTask.resume()
### Open the demo and request permission
Save the page below as `devices-demo.html` and open it over HTTPS (or `localhost`). Paste the SAT and click **Connect** — the log reports the WebSocket coming up. Click **Request permission** to drive the browser's prompt; the three dropdowns populate with labelled devices.
Pick a different mic, camera, or speaker before dialing. The log records each pick as `preference: …` — that's the `client.select*` branch in action. Plug or unplug a USB headset to see `deviceRecovered$` fire.
#### devices-demo.html — full source
```html
<!doctype html>
<html lang="en">
  <head>
    <meta charset="utf-8" />
    <title>SignalWire SDK device-management demo</title>
    <style>
      /* Shared demo shell — identical across the inbound, outbound, and
         device-management guides. Per-demo extras go below this block. */
      body { font: 14px/1.5 system-ui, sans-serif; max-width: 720px; margin: 2rem auto; padding: 0 1rem; }
      label { display: block; margin: 0.75rem 0 0.25rem; font-weight: 600; }
      input, select { width: 100%; padding: 0.5rem; font: 13px ui-monospace, monospace; box-sizing: border-box; }
      button { margin: 0.5rem 0.5rem 0 0; padding: 0.5rem 1rem; font: 14px system-ui; cursor: pointer; }
      button[disabled] { opacity: 0.5; cursor: not-allowed; }
      .videos { display: grid; grid-template-columns: 1fr 1fr; gap: 0.5rem; margin-top: 1rem; }
      video { width: 100%; background: #000; border-radius: 4px; aspect-ratio: 4/3; }
      #log { margin-top: 1rem; padding: 1rem; background: #111; color: #0f0; font: 13px ui-monospace, monospace; min-height: 6rem; white-space: pre-wrap; border-radius: 4px; }
      /* Device-management-specific */
      .devices { display: grid; grid-template-columns: 1fr 1fr 1fr; gap: 0.5rem 1rem; margin-top: 1rem; }
      .devices > div { display: flex; flex-direction: column; }
    </style>
  </head>
  <body>
    <h1>SignalWire SDK device-management demo</h1>
    <label for="token">Subscriber Access Token</label>
    <input id="token" type="password" placeholder="Paste your SAT here" />
    <button id="connect">Connect</button>
    <button id="perms" disabled>Request permission</button>
    <div class="devices">
      <div>
        <label for="mic">Microphone</label>
        <select id="mic"><option>(none)</option></select>
      </div>
      <div>
        <label for="cam">Camera</label>
        <select id="cam"><option>(none)</option></select>
      </div>
      <div>
        <label for="speaker">Speaker</label>
        <select id="speaker"><option>(none)</option></select>
      </div>
    </div>
    <label for="destination">Destination</label>
    <input id="destination" type="text" placeholder="/public/test-room" />
    <button id="dial" disabled>Dial</button>
    <button id="hangup" disabled>Hang up</button>
    <div class="videos">
      <video id="local" autoplay muted playsinline></video>
      <video id="remote" autoplay playsinline></video>
    </div>
    <pre id="log"></pre>
    <script type="module">
      import { SignalWire, StaticCredentialProvider } from "https://esm.sh/@signalwire/js@dev";
      const log = (msg) =>
        (document.getElementById("log").textContent += msg + "\n");
      const $ = (id) => document.getElementById(id);
      let client = null;
      // Cache the latest list + selection per kind so each subscription can
      // rerender the picker without pulling in observable combinators.
      const state = {
        mic: { list: [], selected: null },
        cam: { list: [], selected: null },
        speaker: { list: [], selected: null },
      function populate(kind) {
        const selectEl = $(kind);
        const { list, selected } = state[kind];
        selectEl.innerHTML = "";
        for (const d of list) {
          const opt = new Option(d.label || `Device ${d.deviceId.slice(0, 6)}`, d.deviceId);
          if (selected && d.deviceId === selected.deviceId) opt.selected = true;
          selectEl.append(opt);
        if (!list.length) selectEl.innerHTML = "<option>(none)</option>";
      $("connect").onclick = () => {
        const token = $("token").value.trim();
        if (!token) return log("Paste a token first.");
        $("connect").disabled = true;
        log("Connecting...");
        client = new SignalWire(new StaticCredentialProvider({ token }));
        client.errors$.subscribe((err) =>
          log("Error: " + (err.name || "Error") + " — " + err.message),
        client.audioInputDevices$.subscribe((list) => { state.mic.list = list; populate("mic"); });
        client.selectedAudioInputDevice$.subscribe((d) => { state.mic.selected = d; populate("mic"); });
        client.videoInputDevices$.subscribe((list) => { state.cam.list = list; populate("cam"); });
        client.selectedVideoInputDevice$.subscribe((d) => { state.cam.selected = d; populate("cam"); });
        client.audioOutputDevices$.subscribe((list) => { state.speaker.list = list; populate("speaker"); });
        client.selectedAudioOutputDevice$.subscribe((d) => { state.speaker.selected = d; populate("speaker"); });
        client.deviceRecovered$.subscribe((e) =>
          log(`auto-switch: ${e.kind} (${e.reason}) → ${e.newDevice?.label ?? "system default"}`),
        $("perms").disabled = false;
        $("dial").disabled = false;
        log("Connected. Click Request permission to populate labels.");
      $("perms").onclick = async () => {
        log(`permission: audio=${result.audio} video=${result.video}`);
      // Single picker handler used by all three <select> elements.
      // Routes through call.self when a call is up, client.* otherwise —
      // matches the combined handler from the "Apply the user's choice" section.
      function pick(kind) {
        const list =
          kind === "mic" ? client.audioInputDevices :
          kind === "cam" ? client.videoInputDevices :
          client.audioOutputDevices;
        const device = list.find((d) => d.deviceId === $(kind).value);
        if (!device) return;
        if (activeCall?.self && kind !== "speaker") {
          if (kind === "mic") activeCall.self.selectAudioInputDevice(device, { savePreference: true });
          if (kind === "cam") activeCall.self.selectVideoInputDevice(device, { savePreference: true });
          log(`live: ${kind} → ${device.label}`);
        } else if (kind === "speaker") {
          client.selectAudioOutputDevice(device);
          client.applySelectedAudioOutputDevice($("remote"));
          log(`speaker → ${device.label}`);
        } else {
          if (kind === "mic") client.selectAudioInputDevice(device);
          if (kind === "cam") client.selectVideoInputDevice(device);
          log(`preference: ${kind} → ${device.label}`);
      $("mic").onchange = () => pick("mic");
      $("cam").onchange = () => pick("cam");
      $("speaker").onchange = () => pick("speaker");
      $("dial").onclick = async () => {
        const to = $("destination").value.trim();
        if (!to) return log("Enter a destination first.");
        $("dial").disabled = true;
        log("Dialing " + to + "...");
          activeCall = await client.dial(to, { audio: true, video: true });
          $("hangup").disabled = false;
          activeCall.localStream$.subscribe((s) => ($("local").srcObject = s));
          activeCall.remoteStream$.subscribe(async (s) => {
            $("remote").srcObject = s;
            if (client.selectedAudioOutputDevice) {
              await client.applySelectedAudioOutputDevice($("remote"));
          activeCall.status$.subscribe((status) => {
            log("Status: " + status);
            if (status === "destroyed") {
              activeCall = null;
              $("hangup").disabled = true;
        } catch (err) {
          log("dial() rejected: " + (err.name || "Error") + " — " + err.message);
      $("hangup").onclick = () => { if (activeCall) activeCall.hangup(); };
    </script>
  </body>
</html>
### Switch a device mid-call
Enter a destination in the **Destination** field (a `/public/<resource>`, `/private/<user>`, PSTN number, or SIP URI the token can reach — see [Outbound Calls](/docs/browser-sdk/v4/guides/outbound-calls#pick-a-destination) for the destination shapes) and click **Dial**. The local and remote tiles populate once the call connects.
With the call connected, change the **Microphone** or **Camera** dropdown again. The log now records the change as `live: …` — the picker is routing through `activeCall.self.selectAudioInputDevice()` instead of the client-level preference, and the remote side hears or sees the new device immediately without renegotiation. Picking a new **Speaker** triggers `applySelectedAudioOutputDevice()` on the remote `<video>` element so the sink swaps too.
Click **Hang up** and try the dropdowns again — the log goes back to `preference: …` because `activeCall` is `null`. That's the combined handler from the [Apply the user's choice](#apply-the-users-choice) section, end to end.
## Next steps
#### [Troubleshooting](/docs/browser-sdk/v4/guides/troubleshooting)
Black video, missing audio, denied permissions.
#### [DeviceController reference](/docs/browser-sdk/v4/reference/interfaces/device-controller)
Every device-related property and method on the client.
