# Call Controls
Every control on a call follows the same shape: **call a mutator,
subscribe to the matching `$` observable for state.** The server is
the source of truth — a moderator can mute you, the room can lock
itself, the platform can disconnect. Local state (`let isMuted = …`)
will drift; the observable won't.
This page covers the pattern. Per-method details live in the
[reference].
**You'll need an active call.** Call controls operate on a `Call`
instance — get one of these going first.
Install the SDK and create a `SignalWire` client with a credential provider.
Dial a destination with `client.dial()` to get a `Call` instance.
Subscribe to `client.session.incomingCalls$` and `call.answer()`.
## The pattern
```js
call.self$.subscribe((self) => {
  if (!self) return;
  // Trigger
  muteBtn.onclick = () => self.toggleMute();
  // Reflect — fires once with the current state, then on every change
  self.audioMuted$.subscribe((muted) => {
    muteBtn.classList.toggle("muted", muted);
    muteBtn.textContent = muted ? "Unmute" : "Mute";
Every other control is the same shape with different names —
[`toggleMuteVideo`] / [`videoMuted$`], [`toggleDeaf`] / [`deaf$`],
[`toggleHandraise`] / [`handraised$`], etc.
Three properties make this work:
* **Toggles are idempotent.** Calling [`toggleMute`] mid-flight is
  safe — the SDK serializes.
* **`$` observables emit on subscribe.** The current value arrives
  immediately; no wait-for-event step.
* **The mutator only triggers the change; the observable closes the
  loop.** A moderator-initiated mute that never went through the
  button still updates the UI, because `audioMuted$` emits.
## Where each control lives
Three objects own the controls:
* **`Call`** — session-level: [hangup][`Call.hangup()`],
  [send DTMF][`Call.sendDigits()`], [lock][`Call.toggleLock()`],
  [hold][`Call.toggleHold()`], [transfer][`Call.transfer()`],
  layout (see [Layouts](/docs/browser-sdk/v4/guides/layouts)).
* **`SelfParticipant`** (`call.self`) — your own state: mute, deaf,
  hand raise, [screen share](/docs/browser-sdk/v4/guides/screen-sharing),
  audio processing, your volume.
* **`Participant`** (entries in `call.participants$`) — moderation
  actions on *other* members. Gated by capabilities — see below.
The split mirrors server-side authorization: ending a call needs the
`end` capability, kicking someone needs `member.remove`, muting
yourself is unconditional.
## Mute vs. deaf vs. hold
### Mute vs. deaf
[Mute][`audioMuted$`] silences what *you* send. [Deaf][`deaf$`]
silences what *you* hear. They're independent — you can be deaf
without being muted (you keep talking, but you can't hear responses).
Useful when the user steps away briefly without leaving the room.
### Mute vs. hold vs. push-to-talk
Three ways to stop transmitting audio, and they're not interchangeable:
| Action                              | What it does                                 | Latency                 | Use for                     |
| [`toggleMute`][`audioMuted$`]       | Disables the audio track server-side         | Round-trip              | Standard mute button        |
| [`toggleHold`][`Call.toggleHold()`] | Pauses media transmission for the whole call | Round-trip              | "Be right back" / call park |
| Push-to-talk (local pipeline)       | Sets local mic gain to 0 — track stays alive | Instant (no round-trip) | Walkie-talkie UIs           |
For instant talk/silence transitions (e.g. holding spacebar), use
push-to-talk — mute would feel laggy because the round-trip is visible
to the user:
```js
call.enablePushToTalk();
document.addEventListener("keydown", (e) => {
  if (e.code === "Space") call.setPushToTalkActive(true);
document.addEventListener("keyup", (e) => {
  if (e.code === "Space") call.setPushToTalkActive(false);
The local audio pipeline also gives you [`localAudioLevel$`] for a
real-time meter and [`localSpeaking$`] for VAD-based speaking
detection — both are observables of the local mic, computed
client-side, fast enough for \~30fps UI updates.
## DTMF, timing matters
[`sendDigits`][`Call.sendDigits()`] only succeeds once `status$` is
`'connected'`. Sending before media is negotiated will fail or be
dropped:
```js
import { filter, take } from "rxjs";
call.status$
  .pipe(filter((s) => s === "connected"), take(1))
  .subscribe(async () => {
    await call.sendDigits("1234#");
For interactive dialpads (digits sent as the user presses), wire
the button click directly — by that point the call is connected.
## Moderation — check the capability first
Methods on other participants exist (`participant.mute()`,
`participant.remove()`, `participant.setPosition()`), but calling them
without the corresponding capability throws server-side. Drive the UI
off [`SelfCapabilities.member$`]:
```js
call.self?.capabilities.member$.subscribe((member) => {
  kickButton.hidden = !member.remove;
  muteOthersButton.disabled = !member.muteAudio.on;
If the flag is false, hide the button. See
[Capabilities](/docs/browser-sdk/v4/guides/capabilities) for the
full model.
## Handling unsuccessful attempts
Most toggles resolve cleanly, but three categories can throw — handle
them, don't let an unhandled rejection bubble up:
| Source             | When it throws        | What to do                                                           |
| Browser permission | `unmuteVideo()` or `selectVideoInputDevice()` after the user denied camera access at the OS level | Catch `NotAllowedError` and prompt the user to re-enable in settings |
| Server capability  | Moderation methods (`participant.mute()`, `participant.remove()`) without the right capability    | Gate the button on [`SelfCapabilities`] — don't catch, just hide it  |
| Connection state   | `sendDigits()` before `status$` is `'connected'`, anything after the call has ended               | Subscribe to `status$` and gate calls on `'connected'`               |
Only browser-permission errors need a try/catch on each click.
Capability errors shouldn't be reachable — gate the button instead.
Connection-state errors are prevented by waiting on `status$` (see
[DTMF, timing matters](#dtmf-timing-matters)).
```js
muteVideoBtn.onclick = async () => {
    await call.self.toggleMuteVideo();
  } catch (err) {
    if (err?.name === "NotAllowedError") {
      showToast("Camera access is blocked. Allow camera in your browser settings.");
      return;
    console.error("Failed to toggle video:", err);
The pure-mute toggles ([`toggleMute`], [`toggleDeaf`]) don't require
any browser permission — they only flip server-side state — so they
won't throw on permission. They can still throw on capability or
connection state.
## Example: control bar
Every button uses the same mutator + observable shape:
```js
  if (!self) return;
  // Triggers
  videoBtn.onclick  = () => self.toggleMuteVideo();
  deafBtn.onclick   = () => self.toggleDeaf();
  handBtn.onclick   = () => self.toggleHandraise();
  hangupBtn.onclick = () => call.hangup();
  // Reflections
  self.audioMuted$.subscribe((m)   => muteBtn.classList.toggle("muted", m));
  self.videoMuted$.subscribe((m)   => videoBtn.classList.toggle("muted", m));
  self.deaf$.subscribe((d)         => deafBtn.classList.toggle("active", d));
  self.handraised$.subscribe((h)   => handBtn.classList.toggle("active", h));
Volume sliders, audio-processing toggles, the screen-share button,
and moderation actions all follow the same shape.
## Reference
For the full surface — every method and every observable — see the
per-class reference:
* [`Participant`] — mute, deaf, hand raise, audio processing, server-mixed volumes; also the surface for moderation actions on other members ([`remove`], [`end`], [`setPosition`]).
* [`SelfParticipant`] — adds [`enableStudioAudio`] / [`disableStudioAudio`] on top of `Participant`.
* [`WebRTCCall`] — session-level controls: [`hangup`], [`sendDigits`], [`toggleLock`], [`toggleHold`], [`transfer`], local-mic pipeline ([`setLocalMicrophoneGain`], [`localAudioLevel$`], [`localSpeaking$`], [`enablePushToTalk`], [`setPushToTalkActive`]).
* [`SelfCapabilities`] — server-authoritative flags for gating moderation UI; see [Capabilities](/docs/browser-sdk/v4/guides/capabilities).
[reference]: /docs/browser-sdk/v4/reference
[`Participant`]: /docs/browser-sdk/v4/reference/participant
[`SelfParticipant`]: /docs/browser-sdk/v4/reference/self-participant
[`WebRTCCall`]: /docs/browser-sdk/v4/reference/webrtc-call
[`SelfCapabilities`]: /docs/browser-sdk/v4/reference/self-capabilities
[`SelfCapabilities.member$`]: /docs/browser-sdk/v4/reference/self-capabilities/member$
[`toggleMute`]: /docs/browser-sdk/v4/reference/participant/toggle-mute
[`toggleMuteVideo`]: /docs/browser-sdk/v4/reference/participant/toggle-mute-video
[`toggleDeaf`]: /docs/browser-sdk/v4/reference/participant/toggle-deaf
[`toggleHandraise`]: /docs/browser-sdk/v4/reference/participant/toggle-handraise
[`audioMuted$`]: /docs/browser-sdk/v4/reference/participant/audio-muted$
[`videoMuted$`]: /docs/browser-sdk/v4/reference/participant/video-muted$
[`deaf$`]: /docs/browser-sdk/v4/reference/participant/deaf$
[`handraised$`]: /docs/browser-sdk/v4/reference/participant/handraised$
[`Call.hangup()`]: /docs/browser-sdk/v4/reference/webrtc-call/hangup
[`Call.sendDigits()`]: /docs/browser-sdk/v4/reference/webrtc-call/send-digits
[`Call.toggleLock()`]: /docs/browser-sdk/v4/reference/webrtc-call/toggle-lock
[`Call.toggleHold()`]: /docs/browser-sdk/v4/reference/webrtc-call/toggle-hold
[`Call.transfer()`]: /docs/browser-sdk/v4/reference/webrtc-call/transfer
[`localAudioLevel$`]: /docs/browser-sdk/v4/reference/webrtc-call/local-audio-level$
[`localSpeaking$`]: /docs/browser-sdk/v4/reference/webrtc-call/local-speaking$
[`hangup`]: /docs/browser-sdk/v4/reference/webrtc-call/hangup
[`sendDigits`]: /docs/browser-sdk/v4/reference/webrtc-call/send-digits
[`toggleLock`]: /docs/browser-sdk/v4/reference/webrtc-call/toggle-lock
[`toggleHold`]: /docs/browser-sdk/v4/reference/webrtc-call/toggle-hold
[`transfer`]: /docs/browser-sdk/v4/reference/webrtc-call/transfer
[`setLocalMicrophoneGain`]: /docs/browser-sdk/v4/reference/webrtc-call/set-local-microphone-gain
[`enablePushToTalk`]: /docs/browser-sdk/v4/reference/webrtc-call/enable-push-to-talk
[`setPushToTalkActive`]: /docs/browser-sdk/v4/reference/webrtc-call/set-push-to-talk-active
[`remove`]: /docs/browser-sdk/v4/reference/participant/remove
[`end`]: /docs/browser-sdk/v4/reference/participant/end
[`setPosition`]: /docs/browser-sdk/v4/reference/participant/set-position
[`enableStudioAudio`]: /docs/browser-sdk/v4/reference/self-participant/enable-studio-audio
[`disableStudioAudio`]: /docs/browser-sdk/v4/reference/self-participant/disable-studio-audio
