Release Date 2019-05-13
What's new
- [FS-11567] - Fix CentOS RPM packaging
- [FS-11774] - Quiet down logs from conference moderator command over verto
- [FS-11806] - Fix osx build error in mod_sofia
Improvements
- [FS-11159] - Set the transport based on next hop
- [FS-11721] - Improve msrp
- [FS-11745] - [mod_verto] Add audio JB size and RTCP delay to verto config
- [FS-11753] - Tweak vad test and debug
- [FS-11754] - Sync audio before detect
- [FS-11768] - Llet non-moderator control their own channel like mute/deaf etc
- [FS-11773] - Add callID to conference private event
- [FS-11775] - Wait_for_silence debug messages showing as ERR
- [FS-11781] - Test framework improvements
- [FS-11784] - Quiet some noisy logs
- [FS-11785] - Fix scan-build errors
- [FS-11791] - Mod_kazoo fixes & improvements
- [FS-11801] - Allow deletion of running task
- [FS-11805] - Apply NAT session timeout on outbound calls
- [FS-11810] - Make mod_httapi fetch_cache_data error logs better
- [FS-11813] - Remove libtpl dependency from FreeSWITCH
- [FS-11816] - Update libsrtp to latest 2.2.0
- [FS-11820] - Check read_frame_callback in switch_ivr_sleep
- [FS-11824] - Add a SWITCH_CAUSE that maps to 607 Unwanted
- [FS-11831] - Add fs_tts to generate tts
- [FS-11839] - Update libks to 1.3.0 and signalwire-client-c to 1.2.0 on Windows
Resolved Issues
- [FS-9894] - mod_callcenter: timeout to call an agent hardcoded to 60sec
- [FS-11342] - HEP and HEP3 has incorrect capture_id
- [FS-11696] - format_fields field in AMQP producer not fully initialized
- [FS-11725] - Fix core tests
- [FS-11790] - mod_loopback sends wrong lnfo in loopback::direct event
- [FS-11792] - Memory leak observed in Freeswitch core
- [FS-11807] - uuid_recv_dtmf wrong error response
- [FS-11818] - Fix memory leak when using dial handle
- [FS-11822] - re-upgrade video failed
- [FS-11823] - Fix memory leak in session
- [FS-11825] - auth blind settings not allowing fallback to challenge
- [FS-11830] - memory leak in mod_enum
- [FS-11832] - payload for video is not correct after reinvite
- [FS-11837] - Add feature to allow execution of an app on audio change, execute_on_audio_change variable
- [FS-11838] - kazoo tweaks not properly handling intercept event
