Release Date 2020-4-05
What's new
This release is a minor bug fix containing important changes removing memory errors, resolving potential crashes and misbehaviors.
How to get it
- Debian Packaging: https://freeswitch.org/confluence/display/FREESWITCH/Debian+10+Buster+%28applies+for+Stretch%29+for+SignalWire+STACK
- CentOS: https://freeswitch.org/confluence/display/FREESWITCH/CentOS+7+and+RHEL+7+for+SignalWire+STACK
- Windows: https://fsa.freeswitch.com/downloads/windows/x64/release/FreeSWITCH-20.19.2-Release-x64.msi
- Windows Sound Packages: http://files.freeswitch.org/windows/installer/x64/sounds/
- Source Tarball: https://fsa.freeswitch.com/downloads/freeswitch-releases/freeswitch-20.19.2.-release.tar.gz
Improvements
[Build-System] Enable mod_ilbc Debian packaging. [build/test] git ignore test output [Configuration] sip_profiles: Use ${external_sip_ip} for ext-sip-ip, ${external_rtp_ip} for ext-rtp-ip [Core] Add systemd sd_notify support [mod_av] Don't require .ext for streaming rtmp:// and rtsp:// formats [mod_av] reduce some errors to warnings in logs [mod_conference] Add conference::maintenance conference-heartbeat. [mod_fifo] adding 'noans' and 'early' call status options and dtmf '0' disable config settings option [mod_kazoo] add event stream connected time [mod_shout] Reduce log level from error to warning for "Error opening %s (invalid rate or channel count)" [mod_sofia] Add new gateway param 'contact-in-ping' to support Microsoft Teams Direct Routing [mod_sofia] Adding custom header to refer [mod_sofia] Include isup-oli parameter on outbound invite when we have value in caller profile [mod_valet_parking] Add valet_parking_orbit_exit_key option [sofia-sip] Build internal tests [Testing] Add mod_portaudio, mod_redis, mod_skinny to scan-build on Drone Add git configuration to ignore errors from `git fsck`
Resolved Issues
[core,mod_verto,mod_xml_rpc] Fix use of deprecated CRYPTO_set_id_callback(). [Core] Adding fix for switch_ivr_originate to not copy group_confirm variables to the channel [core] eavesdrop: reduce lock contention, fix error condition + enable eavesdrop stereo . [Core] Fix dereference of null pointer in video_bridge_thread() when codec b is not yet initialized. [Core] Fix leak in switch_xml_set_attr(). Add case to a unit test. [Core] Fix locking and a memory leak in switch_core_session_write_video_frame() and switch_core_session_write_text_frame(). [core] Fix regression in play_and_collect_input [mod_av] enable resampler when sample rate mismatch [mod_conference] fix crash when using conference heartbeat [mod_erlang_event] Fix segfault in destroy_listener() [mod_httapi] Fix leak of context->url_params [mod_mariadb] Fix reconnect during db failover/restart [mod_opusfile] unit-tests: add timer to fix random test failures due to the fact that the decoding callback is not installed immediately [mod_sndfile] fix read sndfiles with float data [mod_sofia] Fix potential buffer overrun when rewrite_multicasted_fs_path is enabled. [mod_sofia] Fix rtp config ipv4/ipv6 index confusion [mod_sofia] remove blank display name that can show up in from uri [sofia-sip] fix build on newer clang [sofia-sip] Fix crash in timer B outgoing_timer_bf() which asserts if INVITE request was completed already. [sofia-sip] Fix use of deprecated CRYPTO_set_id_callback().
