8 min
SignalWire AI Gateway (SWAIG) and How it Compares to MCP
Why SWAIG is the realized vision of AI gateways (versus MCP)
Anthony Minessale
Anthony Minessale
CEO
PUC
The Model Context Protocol (MCP) offers a conceptual standard for structured interactions between AI models and external tools, but in practice many implementations are early-stage and not suited to real-time applications. SignalWire AI Gateway (SWAIG) instead provides a mature, production-ready AI gateway used today to power real-time voice and messaging applications with declarative functions and runtime orchestration. This article explains the differences in design, implementation, maturity, and developer experience between the MCP vision and SWAIG’s operational capabilities.
Understanding the SignalWire AI Gateway and the Model Context Protocol
The emergence of the Model Context Protocol (MCP) has sparked excitement across the AI and developer ecosystems. Positioned as a forward-looking standard for enabling large language models (LLMs) to securely access external tools, data, and context, MCP proposes a structured, extensible framework that emphasizes modularity, consent, and safety. It introduces concepts like resources, tools, and prompts, bound together by role-based interactions that could allow AI assistants to perform meaningful actions.
But while MCP defines an ambitious blueprint, SignalWire has already built and operationalized this vision. SWAIG, the SignalWire AI Gateway, is a mature, production-grade protocol and runtime system powering real-world AI agents across telecom channels at scale. From programmable voice workflows to real-time messaging orchestration, SWAIG is not just a concept. It is the infrastructure behind live applications.
This post explores why SWAIG stands as the realized model of an AI Gateway, showcasing practical features, declarative simplicity, and battle-tested execution environments that MCP has yet to reach. MCP paints a compelling vision of how AI integrations might work; SWAIG demonstrates how they already do: cleanly, scalably, and securely.
The core philosophy
Both SWAIG and MCP share a foundational goal: to move toward the future of ai agents. A future that moves beyond passive response generation and toward safe, structured interaction with the world. An AI Gateway Protocol must allow LLMs to execute actions with contextual awareness and operational control.
MCP introduces this through a layered, declarative model composed of resources (data), tools (functions), and prompts (task templates). It separates system roles-Host, Client, Server-and suggests negotiation mechanisms for capability discovery and permission granting. The framework promotes modularity and abstraction, and in theory, it supports general-purpose AI models.
However, in practice, MCP remains early-stage. Public specifications exist, and reference SDKs are emerging, but MCP's deployment is largely confined to IDE assistants and localized environments. Despite claims of vendor neutrality, most implementations remain experimental or non-secure (e.g., Cursor, Sourcegraph, Windsurf). There is no clear path to secure, real-time decisions-based deployment in production-grade applications.
SWAIG, by contrast, is fully implemented and running live across SignalWire’s programmable voice and messaging infrastructure. It is not a toolkit for building an integration stack. It is the integration stack. SWAIG defines executable functions, validates arguments, manages consent and scope, and routes real-time media-all through a declarative interface embedded in SignalWire’s agent markup language, SWML. It provides the real-time context needed for agentic AI systems.
Rather than conceptual roles, SWAIG delivers operational behavior. Its functions can be serverless (templated calls to APIs) or routed to HTTP services, and they are invoked directly in conversation flows without glue code or orchestration layers. The agent understands how and when to call them, what to do with the results, and how to proceed in the interaction. Essentially, SWAIG enables an ai driven virtual assistant to perform actions.
Design and simplicity
MCP emphasizes a flexible, modular architecture. However, its design requires considerable scaffolding: multiple abstract layers (resources, tools, prompts, metadata, context), permission negotiation, and external orchestration for runtime behavior. This creates overhead and friction for developers trying to build production agents.
SWAIG simplifies this by doing less. Its primitives are compact and expressive: function, parameters, data_map, output, and action. These map directly to behavior and require no separate discovery mechanism or orchestration layer. One YAML or JSON block defines the interface, validation, conversational response, and downstream actions.
Example: Serverless function with data map
- function: get_weather
 purpose: Get the current weather based on the user's location
 argument:
 type: object
 properties:
 type: string
 description: The name of the city or zip code
 data_map:
 expressions:
 - pattern: ".*"
 string: "${args.location}"
 output:
 response: "Weather data retrieved."
 action:
 - SWML:
 version: "1.0.0"
 sections:
 main:
 - send_sms:
 to_number: "+15554441234"
 region: "us"
 body: "Here's the weather for ${args.location}"
 from_number: "+15554441234"
 argument:
 type: object
 properties:
 type: string
 data_map:
 expressions:
 - pattern: ".*"
 output:
 action:
 - SWML:
 version: "1.0.0"
 sections:
 main:
 - send_sms:
 region: "us"
 argument:
 type: object
 properties:
 type: string
 data_map:
 expressions:
 - pattern: ".*"
 output:
 action:
 - SWML:
 version: "1.0.0"
 sections:
 main:
 - send_sms:
 region: "us"
 argument:
 type: object
 properties:
 type: string
 data_map:
 expressions:
 - pattern: ".*"
 output:
 action:
 - SWML:
 version: "1.0.0"
 sections:
 main:
 - send_sms:
 region: "us"
Example: Hosted function with webhook
 description: To determine the current weather for a given location.
 parameters:
 type: object
 properties:
 type: string
 description: The location to check
 fillers:
 en-US:
 - "Checking the weather for you."
 web_hook_url: https://api_key:secret_token@your-swaig-server.com/get_weather
 parameters:
 type: object
 properties:
 type: string
 fillers:
 en-US:
 parameters:
 type: object
 properties:
 type: string
 fillers:
 en-US:
 parameters:
 type: object
 properties:
 type: string
 fillers:
 en-US:
Expected server response:
 "response": "It’s currently 72°F with clear skies in Austin, Texas.",
 "action": {
 "set_meta_data": {
 "last_checked_location": "Austin"
 "action": {
 "set_meta_data": {
 "action": {
 "set_meta_data": {
 "action": {
 "set_meta_data": {
In this model:
  • response shapes the next AI turn
  • action defines operational behavior (e.g., say, transfer, metadata)
No external discovery. No runtime glue. All validated and run in context.
Integration in the real world
MCP’s primary integrations today are with IDE copilots and developer tools. These environments are constrained, localized, and generally asynchronous. They are valuable but limited in operational scope.
SWAIG is deployed in live telecom flows: PSTN, SIP, WebRTC, and SMS. A SWAIG agent can receive a phone call, parse speech via STT, call a serverless function, respond via TTS, and take action-all within a single call session. It runs real-time, across channels, with no intermediary orchestratio
Real world example: Appointment scheduler
  • Define get_availability as a hosted or serverless SWAIG function
  • Ask the user for a time
  • Use data_map to query the booking API
  • Let user pick a time
  • Use send_sms to confirm
No backend logic is required beyond the API call. No IVR scripting. No third-party orchestration.
SWAIG is already in use for:
  • Voice bots answering questions and routing leads
  • SMS agents scheduling appointments or collecting preferences
  • Cross-channel assistants combining messaging, voice, and data
  • Real-time agents integrated with CRMs and operational backends
Security and operational trust
MCP focuses on user-centric permission and abstraction but does not define how runtime environments should enforce execution constraints. This leaves security as an implementation detail-flexible, but inconsistent and risky in operational settings.
SWAIG functions operate within a tightly controlled execution model:
  • JSON Schema defines argument validation
  • Only a fixed set of actions are permitted
  • All functions execute within a call/session context
  • Timeout, barge-in, and state transitions are managed by the platform
  • Transitions and actions are logged and auditable
This yields a deterministic, traceable behavior model where AI actions are predictable and safe.
Examples of allowed actions:
  • say or response: conversational output
  • SWML: telephony instructions (transfer, hold, record)
  • set_meta_data, toggle_functions, stop, etc.
The result is a structured, declarative, and secure environment for AI operations-critical in regulated industries or sensitive applications.
Scalability and deployment
MCP aspires to be language-agnostic and modular. However, it lacks a shared runtime, unified execution model, or deployment guidance. Today, it runs mostly in browser tools or developer IDEs without scale benchmarks or secure endpoint integration.
SWAIG is already deployed across SignalWire’s telecom-grade infrastructure. It inherits FreeSWITCH’s performance and reliability, and has been used in thousands of concurrent voice sessions.
Teams can:
  • Start serverless (API-only functions)
  • Deploy hosted SWAIG servers (Heroku, Fly.io, AWS)
  • Mix real-time calls, SMS, and backend logic
  • Reuse functions across multiple agents
  • Scale incrementally and predictably
This composability allows fast iteration without compromising structure or safety.
Built-in tool hosting and discovery
A unique feature of SWAIG is its ability to dynamically fetch tools from external sources via HTTP POST. Developers can:
  • Host SWAIG-compatible tools on their own server
  • Expose functions via authenticated POST endpoints
  • Register tool URLs in SWML agents declaratively
  • Enable auto-discovery with explicit permission control
This is conceptually similar to MCP’s vision of tool discovery, but significantly simpler. No negotiation protocol, no capability graph. Just set the endpoint, define the schema, and let the agent invoke it.
It is declarative, scalable, and secure, without overengineering.
How MCP could learn from SWAIG
MCP’s structure is thoughtful, but early implementations lack the constraints and integration patterns required for production readiness. It could evolve faster by adopting elements from SWAIG:
  1. Data-first execution models
    • Instead of resource abstractions, SWAIG uses data_map blocks to bind inputs to live data.
  2. Declarative action flows
    • SWAIG returns typed, structured action blocks that eliminate ambiguity.
  3. Lifecycle integration
    • SWAIG functions execute within voice/messaging sessions and manage state transitions.
  4. Unified format
    • SWAIG functions behave the same whether serverless or hosted-minimizing mental overhead.
MCP’s principles are solid, but operational grounding is what transforms protocols into platforms. SWAIG illustrates that real-world design requires execution, not just abstraction.
Operational milestones
SWAIG has been running in production since early 2023, integrated directly into SignalWire’s global telecom infrastructure. It has handled thousands of concurrent real-time voice sessions.
This operational maturity is not speculative. It reflects learnings and refinements from live deployments in regulated, customer-facing environments.
MCP is a promising attempt to define the future of LLM-driven tools. It is modular, extensible, and aligned with privacy-first principles. But while it proposes how AI Gateways might work, SWAIG proves how they already do work, today.
SWAIG is declarative, enforceable, composable, and live in production. It eliminates unnecessary complexity, runs directly in the SignalWire platform, and powers real-time voice and messaging AI agents.
It is not a concept. It is a framework. It closes the loop between intent and action, between specification and behavior, between architecture and execution.
For organizations looking to operationalize AI agents today, not in theory, SWAIG provides the shortest path from design to deployment. It is the blueprint for operational AI agents. And it is already live.
What is the Model Context Protocol (MCP)?
The Model Context Protocol (MCP) is an emerging standard that defines how AI systems can access external tools, data, and structured context through a unified schema of resources, tools, and prompts, aiming for modular, secure interactions between models and applications.
What is the SignalWire AI Gateway (SWAIG)?
SWAIG is a production-grade AI gateway used on the SignalWire platform that provides declarative function integration, argument validation, context handling, and real-time runtime execution for AI voice and messaging agents.
How do SWAIG and MCP differ in real-world usage?
MCP remains largely a conceptual and early-stage framework with experimental implementations, while SWAIG is already operational in high-throughput, low-latency environments and integrated into real-time communication applications.
Why might a developer choose SWAIG over MCP today?
Developers might choose SWAIG for production voice, messaging, or real-time agent applications because it has an executable runtime, simple declarative primitives, and direct support for operational contexts that MCP currently lacks at scale.
