5 min
Build a Nursing Home AI Agent for Health Assessments
Health assessments powered by SignalWire’s AI Agent
Daniele Zils
Technical Success Manager
Developer Tutorials
Nursing home staff spend significant time on routine check-ins that follow predictable patterns but still require accurate data capture, identity verification, and compliant handling of resident information. This article explains how to build a HIPAA-conscious nursing home AI agent with SignalWire that calls residents weekly, verifies each patient against a local database, collects structured health assessment answers, uses Datasphere to fetch educational guidance when needed, and then summarizes and stores results while notifying caregivers in real time.
Creating expert AI agents with SWML and Datasphere
The SignalWire AI Agent allows you to develop custom digital assistants that are compliant with the regulations of specific industries. SignalWire Markup Language (SWML) creates AI-powered call flows, while Datasphere (SignalWire’s RAG API) can be used to build knowledge bases for AI agents to become experts in specific topics.
In this post, we’ll walk through an example of a HIPAA-compliant AI agent for a nursing home that automates routine weekly check-ins with residents. This AI assistant transforms a repetitive, hands-on process into a fully automated workflow, ensuring vital information promptly reaches caregivers without missing a beat.
We’ll show you exactly how to set up the call flow with SWML and demonstrate how to leverage SignalWire AI Gateway (SWAIG) functions, like verify_patient and store_summary, to connect to a local database. This will confirm each patient’s identity and log their assessment results in real-time.
To access the full code, view the SignalWire in Seconds GitHub repository.
How the AI nursing home digital assistant works
  1. Patient verification: The AI agent calls a patient, asks for their name, and verifies it against a local database.
  2. Health assessment: The AI collects key information about well-being, pain, appetite, and sleep quality.
  3. Datasphere queries: If the patient needs more information about a symptom, the AI can fetch relevant paragraphs from a stored document (such as a PDF of best practices or medical guidelines).
  4. Summarization and notification: After the call, the AI saves a conversation summary in the database and texts the caregiver with a conversation summary.
SWML: The conversation blueprint
SWML is a JSON or YAML based markup language used to define call flows, IVRs, AI interactions, and other telephony logic in a flexible, declarative format. In this example, it orchestrates how the AI agent interacts with the patient. Below is an abridged snippet from our SWML prompt that highlights the conversation flow:
copy
01
02
03
04
05
06
07
08
09
  "ai": {
    "params": {
      "verbose_logs": true
    "prompt": {
      "temperature": 1.5,
      "top_p": 1.0,
      "text": "# System Prompt for Nursing Home Health Assessment Agent\\n\\n
**Objective:**\\n
You are Adam, and you conduct health assessments for HealthyStay Nursing Home.\\n\\n
**Key Call Guidelines:**\\n
1. **Introduction:** Greet the patient warmly and introduce yourself.\\n
2. **Verify Patient:** Ask for the patient's first and last name, and only call the verify_patient function **after** obtaining both names. Use that info to look up their record and caregiver phone.\\n
3. **Conduct Assessment:** Ask a few health questions for their weekly health assessment:\\n
   - How are you feeling overall?\\n
   - Any pain or discomfort?\\n
   - Changes in appetite, or weight?\\n
   - How is your overall sleep quality?\\n
4. **Provide Guidance:** Ask if they need more info about symptoms, and if yes, call the get_data function.\\n
5. **Summarize and Store:** After summarizing, **call the store_summary function** with the final conversation summary so it is saved in the database.\\n
6. **Send SMS:** Then call send_message to text the summary to the caregiver (without reconfirming the caregiver number)."
copy
01
02
03
04
05
06
07
08
09
  "ai": {
    "params": {
    "prompt": {
      "temperature": 1.5,
      "top_p": 1.0,
**Objective:**\\n
copy
01
02
03
04
05
06
07
08
09
  "ai": {
    "params": {
    "prompt": {
      "temperature": 1.5,
      "top_p": 1.0,
**Objective:**\\n
copy
01
02
03
04
05
06
07
08
09
  "ai": {
    "params": {
    "prompt": {
      "temperature": 1.5,
      "top_p": 1.0,
**Objective:**\\n
SWAIG functions
Below is a quick look at how verify_patient is defined in SWML as a SWAIG function and how it corresponds to a Flask endpoint.
copy
01
02
03
04
05
06
07
08
09
  "function": "verify_patient",
  "purpose": "Verify patient's first and last name in the local database",
  "data_map": {
    "webhooks": [
        "method": "POST",
        "url": "https://REPLACE_WITH_YOUR_ENDPOINT/verify_patient",
        "params": {
          "first_name": "${args.first_name}",
          "last_name": "${args.last_name}"
        "output": {
          "response": "Verified ${Records[0].first_name} ${Records[0].last_name}. Caregiver phone: ${Records[0].caregiver_phone}",
          "action": [
              "set_meta_data": {
                "caregiver_phone": "${Records[0].caregiver_phone}",
                "patient_id": "${Records[0].id}"
  "meta_data_token": "patient_meta"
copy
01
02
03
04
05
06
07
08
09
  "data_map": {
    "webhooks": [
        "method": "POST",
        "params": {
        "output": {
          "action": [
              "set_meta_data": {
copy
01
02
03
04
05
06
07
08
09
  "data_map": {
    "webhooks": [
        "method": "POST",
        "params": {
        "output": {
          "action": [
              "set_meta_data": {
copy
01
02
03
04
05
06
07
08
09
  "data_map": {
    "webhooks": [
        "method": "POST",
        "params": {
        "output": {
          "action": [
              "set_meta_data": {
With meta_data_token = "patient_meta", each SWML function referencing the same token can read or update the meta_data object. This avoids repetition of fetching basic details (like phone numbers or IDs) every time. Instead, store_summary or send_message simply uses "${meta_data.patient_id}".
/verify_patient endpoint response
copy
01
02
03
04
05
06
07
08
09
@app.route('/verify_patient', methods=['POST'])
def verify_patient():
    # ... (input validation, DB lookup, etc.) ...
    # If match is found
    return jsonify({
        "response": f"Found patient {found_fname} {found_lname}. "
                    f"Caregiver is {caregiver_name}, phone: {caregiver_phone}",
        "Records": [
                "id": patient_id,
                "first_name": found_fname,
                "last_name": found_lname,
                "dob": dob,
                "patient_phone": patient_phone,
                "caregiver_name": caregiver_name,
                "caregiver_phone": caregiver_phone
    # If no match is found
    return jsonify({
        "response": "No matching record found. Please provide your first and last name again.",
        "Records": [],
        "retry": True
copy
01
02
03
04
05
06
07
08
09
    # If match is found
    return jsonify({
        "Records": [
                "id": patient_id,
                "dob": dob,
    return jsonify({
        "Records": [],
        "retry": True
copy
01
02
03
04
05
06
07
08
09
    # If match is found
    return jsonify({
        "Records": [
                "id": patient_id,
                "dob": dob,
    return jsonify({
        "Records": [],
        "retry": True
copy
01
02
03
04
05
06
07
08
09
    # If match is found
    return jsonify({
        "Records": [
                "id": patient_id,
                "dob": dob,
    return jsonify({
        "Records": [],
        "retry": True
Datasphere: Retrieving paragraph-level information
Datasphere processes text documents like PDFs, splits them into smaller, searchable sections, and stores them as vectors for quick retrieval. This enables the AI agent to fetch knowledge on the fly for accurate, fact-based answers.
For this example, we uploaded a PDF to SignalWire’s Datasphere API using the “paragraph” chunking strategy, meaning the PDF document was formatted into clear paragraph sections.
Chunking strategy
  1. Paragraph splitting: Breaks the document into paragraphs.
  2. Upload to Datasphere: Use the Datasphere API or dashboard UI to store the chunked document, receiving a document_id.
  3. Query in SWML: The get_data function then references that document_id:
copy
01
02
03
04
05
06
07
08
09
  "function": "get_data",
  "data_map": {
    "webhooks": [
        "method": "POST",
        "url": "https://<YOUR_SIGNALWIRE_SPACE>.signalwire.com/api/datasphere/documents/search",
        "headers": {
          "Content-Type": "application/json",
          "Authorization": "Basic OGVhMjI0YzktM--USE--Project_ID:API_KEY--TO-BASE64-ENCODE--NkYjFh"
        "params": {
          "query_string": "${args.user_question}",
          "document_id": "YOUR_DOCUMENT_ID"
        "output": {
                    "response": "Answer the patient's question using the information in this document. Do not make up answers: ${chunks[0].text} (Document ID: ${chunks[0].document_id})",
                        "action": []
copy
01
02
03
04
05
06
07
08
09
  "data_map": {
    "webhooks": [
        "method": "POST",
        "headers": {
        "params": {
        "output": {
                        "action": []
copy
01
02
03
04
05
06
07
08
09
  "data_map": {
    "webhooks": [
        "method": "POST",
        "headers": {
        "params": {
        "output": {
                        "action": []
copy
01
02
03
04
05
06
07
08
09
  "data_map": {
    "webhooks": [
        "method": "POST",
        "headers": {
        "params": {
        "output": {
                        "action": []
If a patient were to ask, “I’ve been having trouble sleeping. What can I do?” the AI calls get_data, sending the question to Datasphere. The best paragraph about sleep or insomnia is returned and read back to the user, removing guesswork from the AI’s response.
Example call flow
Start dialer
From the CRM interface, a staff member clicks “call patients,” triggering the /start_dialer endpoint in Flask. This spawns the dialer.py script, which uses SignalWire RELAY consumer to read each patient’s phone number from nursing_home.db. It then dials those numbers using the from_number configured in the environment.
Once the call successfully connects to a patient, the script bridges that call to the AI agent phone number, where SWML (via /ai_prompt) is set up to handle the conversation logic.
AI introduction
After the dialer script has handed off the call to your digital_assistant number, the SWML "answer" directive takes over. The AI greets the patient and asks for their first and last name, preparing to verify them against your database.
Verify
The AI calls verify_patient (Flask), sending those names. In return, the endpoint provides the patient’s ID and caregiver phone. SWML then stores this in meta_data so it can be used in later steps.
Health questions
The AI proceeds to ask weekly check-in questions like, “How do you feel overall?” “Any pain or discomfort?” “How’s your sleep?”
Further details
If the patient wants more info or has specific concerns, get_data is triggered. This calls Datasphere to retrieve relevant paragraphs from a stored document (like a PDF of health guidelines).
Summarize and send SMS
Finally, the AI calls store_summary to save the call details in the database, and then send_message to text a short summary to the caregiver’s phone number, no extra verification needed.
Get started with SignalWire AI Agents and Datasphere
Using the SignalWire Datasphere with our AI Agent allows smart applications to deliver targeted, helpful answers, improving user experiences and efficiency.
To dive deeper into the code and see how it all fits together, check out the full project in our GitHub repository. Fork the code, experiment, adapt the logic for your own use case, and continue exploring the power of the SignalWire AI Agent.
Start building for free today by signing up for a SignalWire Space, exploring our developer documentation, and bringing your questions to our community on Discord.
What does the nursing home AI agent do?
The nursing home AI agent automatically calls residents on a regular schedule, verifies their identity, walks through a structured health assessment about well-being, pain, appetite, and sleep, and then summarizes the conversation so caregivers receive timely, actionable information without manually running every check-in.
How does the health assessment workflow work end to end?
During each call, the agent verifies the patient’s name against a local database, asks a set of assessment questions, can use Datasphere to fetch additional information if the resident has concerns, and then stores a summary of the call in the database while sending a notification or text update to the caregiver responsible for that resident.
Which SignalWire components does this example use?
This example uses SWML to orchestrate the call flow and conversation, Datasphere as a RAG-style layer to answer symptom-related questions from stored documents, and SWAIG functions such as verify_patient and store_summary to interact with a local database for identity checks and logging results.
Is this nursing home AI agent suitable for HIPAA-conscious environments?
The example is designed around HIPAA-conscious usage by keeping sensitive data in a local database, verifying identity before discussing health details, and using SignalWire’s AI and telephony stack so that calls, media, and AI processing can be handled within a controlled, compliance-friendly environment instead of ad hoc point solutions.
Can I adapt this pattern to other healthcare or check-in workflows?
Yes. The same architecture can be applied to other healthcare and wellness scenarios, such as home health follow-ups, chronic condition monitoring, or post-discharge check-ins, by adjusting the SWML prompt, Datasphere knowledge base, and SWAIG functions to match the questions, documentation, and databases used in your environment.
Does Framer support XYZ?
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur.
